Question about Buffalo Tools BABBS2 Babbs2 2Pc Bamboo Bar Stools
Bamboo barstools not sturdy
Not sturdy, wobble legs different lenghts
    Problem Solver:
  • 17 Answers
That's the quality problem, or you should put it on a flat surface
Posted on Feb 21, 2014
Does the Wacom Intuos2 Classic Pen (xp 300e) work with the Wacom Bamboo CTL 470 tablet?
From what I read on Wacom's site, they are NOT compatible.
The Bamboo use a stylus that is different than the nib pens that the Intuos use. The stylus for the Bamboo is more like the stylus you can purchase for smart phones. The Intuos pens are pressure sensitive and have different nibs you can use for different effects and feel. You can go to their website and look for compatible pens and stylus' for your specific tablet.
Aug 02, 2014 | Wacom Intuos2 Classic Pen (XP-300E)...
My bed frame has started to wobble slightly. What can I do to fix it?
Start by removing all the bedding, including the mattress. Try tightening the screws and bolts holding the bed together, maybe it is a simple problem. If that doesn't work try checking the joints. Sometimes over time they can separate. If this is the case you will need to glue them back in place. Another thing you could check are the legs of the bed frame. Are they all the same length? If not, try putting something sturdy under the short leg to even it out. Hope this helps you.
Aug 16, 2012 | Furniture
What is a scoop barstool?
A scoop barstool is a barstool that is not your conventionalflat bottomed stool. Regular barstoolsare normally made out of wood. Scoopbarstools are generally made of fiberglass and are backless. They are called "scoop" because there is anindentation in the seat to make it more comfortable to sit on. The seat, itself, sort of looks like anice-cream scoop. They also tend toswivel as opposed to being stationary like most barstools.
May 29, 2012 | Furniture
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Washer must be out of balance
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Jan 08, 2009 | Admiral AW22 Top Load Washer
Front Suspension
Try this from sv650.org FAQ list great site try it. Quote Here's a piece for your FAQ section. Oh....OK then.... My reworking of the SV continues - just thought I would send the lazy way of changing the fork oil and adding spacers - without removing the forks! Lets face it, removing the front wheel, mudguard, calipers, forks etc is a right pain - there is a better way and it can be done in under 15 minutes! You need a thin bamboo pole about 3 foot long, 2 metres of 10mm flexible pipe, a bent nail, 1 litre of fork oil and a selection of 35mm washers. You are now ready to convert the washed out front suspension without removing the fork legs and it can be done in under 15 minutes! First loosen the fork caps, now jack up the front wheel clear of the ground. Remove the fork caps completely - dont worry about the caps popping upwards with spring tension, there is none! Remove the metal spacer tubes from inside the forks. Attach your bent nail to bamboo stick with tape, grovell inside forks and pull up to remove spacer washer, then grovel again and remove the spring. Remove bent nail, insert bamboo pole into one leg, until it goes to the bottom - careful, the bottom has a recess in, get it right and you will feel the pole go down another six inches. Pull back out and mark oil level on bamboo stick with black marker pen for reference later. Attach pipe to bamboo stick right at the end and again send to inside of forks, down into recess. Suck on pipe and all the oil will magically drain into can. Catch what can! - Whoops sorry you need a can to catch oil in! Process takes about two minutes and does remove all the oil! Drain second leg same. Pour 480ml of 15 sw oil into first leg, insert bamboo stick and careful top up to reference mark made earlier. Follow suit with second leg. (Mr Suzuki was a full 30mm different from one leg to the other in my SV - you now have two perfectly balanced legs - 489 ml is the correct amount per leg) Insert springs, then amount of washers to increase preload that you require - I inserted 15mm each side and it feels not bad. The washers must be 35mm exactly, anymore and they will not fit inside the legs. I managed to find some at 35.5mm and had to grind the .5mm off. Just drop an equal amount in each leg and top off with the original suzuki washer. Insert the spacers and tighten up the fork caps - you will have to push down hard as you tighten as your washers are now doing their job. Lower jack and burn rubber up the street! Some people prefer thicker 20 sw oil, or more spacers, around 19mm not uncommon. With the rear set on number four, the front now feels matched, doesn't flop when braking and has helped no end with the pitching (UK roads). Rates about a seven on the improvement scale. You could do better and fit aftermarket springs but not for the £8 the above cost inc the oil. So there you have it - the laziest way of uprating the SV front yet!
Nov 10, 2008 | 2006 Suzuki SV 650 S
Bamboo Fun usb device not recognized
Change the USB cable... this is the problem...
Sep 22, 2008 | Wacom Bamboo Fun USB Tablet with Cordless...
Blocked vacuum hose
You'll need a sturdy stick like a thick bamboo stick to push this out but remove the hose FIRST from the vacuum and compact the hose up before inserting the stick. Either that or you may have to order a new hose which can be cheap. What model is it you have?
May 09, 2008 | Vacuums
Crib sturdyness
If it feels as though it wobbles, a likely problem is that the screws have not been fully tightened. They may feel tight, but give them all one good torque turn or two, until you cant anymore, pretty much. It should solve most of the wobble.
Jun 04, 2007 | Childesigns Shelby Crib
Buffalo Tools BABBS2 Babbs2 2Pc Bamboo Bar Stools Logo
493 people viewed this question
Top Buffalo Tools Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Buffalo Tools Furniture Expert? Answer questions, earn points and help others
