Question about Omega 8005 Juicer
Omega 8005 auger makes noise when you turn it on and pulp backs up 1 yr old
After I put fruit or veggies in it gets quieter, but still seams to rub when it goes around. Juice is pulpier than usual.
3 Suggested Answers
sweetymommy
  • 4 Answers
SOURCE: wheatgrass juicing problems
Hi, I have an Omega juicer, and I've never had this happen. I recommend that you double check to see if you have the right parts attached. It comes with two inserts, one with a small metal screen on the bottom, the other has no screen, it is solid. The solid one is for crushing and proccessing food. The one with the screen is used for juicing. Make sure you have the correct one installed. If that is not the problem, I think perhaps the grass is too dry? Maybe there isn't enough moisture in it to extract much. I really can't say, though. Try juicing something else, like carrots, and see if you can get some juice there. If all else fails, contact Omega at their website. They have terrific customer service. I've tested it already with a warranty replacement.
Posted on Aug 06, 2007
SOURCE: wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Posted on Dec 23, 2008
My juice is coming out with the pulp. The machine seems to be operating and sounding normal and this has never happened before. I have the omega 8005 model??
This usually is indication of pulp backing up in the machine make sure you are pre cutting the produce and also make sure the tensioner on the end is adjusted according tot he produce being used. Example: softer produce requires less tension where as leafy green vegetables you can increase the tensioner.
Feb 03, 2013 | Omega 8005 Juicer
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
Mar 08, 2011 | Omega 1000 Juice Extractor
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
My Omega 1000 goes off balance and makes a noise like it is going to blow up so I have to end of turning it off. It doesn't do this all the time but it is getting more frequent. This happens with any...
Yours and everyone else's. Best solution is to get a pulp ejecting type juicer.
I have a 21 year old Acme and know how to maintain and adjust it. Even
then I have vibration issues.
Sep 02, 2010 | Omega 1000 Juice Extractor
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Juicer heating and pulp is wrapping around blades
Parts from Champion website. You may need a new cutter, sometimes cheaper on ebay.
Jun 22, 2008 | Champion 2000+ Household Juice Extractor
Wet pulp
Jan 05, 2008 | Omega 8005 Juicer
Wheatgrass juicing problems
Aug 05, 2007 | Omega 8005 Juicer
Omega 8005 Juicer Logo
65 people viewed this question
Top Omega Juicers Experts
Andrew Taylor
Andrew Taylor
eyecam
Tom Chichester
Are you an Omega Juicer Expert? Answer questions, earn points and help others
