Question about Prozone PZ6 Indoor Air Purifier Black
Need a replacement bulb for a prozone pz6 air purifier
Need replacement bulb
How do you replace the bulb in a freshair purifier
Make sure you have the starter use with replacement bulb. Usually comes with replacement bulb. Open the back of th unit by removing the cover.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
My Ecoquest Fresh Air Purifier is giving me a warning to replace bulb. I don't see anywhere on the manual where the bulb is.
The bulb is in the RCI module for the version 2.0 & 2.1. It the part that is rectangular with a honeycomb grid on two sides. Your dealer should be able to help you get a replacement. If you need more help just leave a comment. Hope this helps you.
Aug 31, 2010 | Ecoquest Fresh Air Air Purifier
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
How do I change the light in my fresh air purifier
The light bulb is a tube style that clips in - - kind of like replacing a flourescent light bulb T-8, T-10 style. Try rotating it so that the end pins align themselves properly for removal. Simple !!
Oct 08, 2009 | Ecoquest Fresh Air Air Purifier
I need to replace the bulb for ionic breeze air purifier S1830
G15T8 15W 15 Watt UV Germicidal Bulb IONIC BREEZE GP
this bulb is available on ebay for under $11.00. The release tab for the cover is at the bottom of the cover and it comes off pretty easy. Once the cover is off you turn the lamp 1/4 turn (two clicks) and slide it from it's fixture.
Jul 01, 2009 | Sharper Image Professional Plus Ionic...
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
BULB AND LAMP
I can give you some possibilities. A loose connection, a broken or corroded wire and/or terminal end, dust or moisture on a circuit board, the plate needs cleaning, the contacts for the plate need cleaning, the bulb ballast needs to be replaced, the bulb may not be properly installed, the support posts for the plate need cleaning. These are all I can think of at the moment.
Jun 18, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest FreshAir - UV Flickering
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Feb 17, 2008 | Ecoquest Fresh Air Air Purifier
Prozone PZ6 Indoor Air Purifier Black Logo
Top Prozone Air Purifiers Experts
Are you a Prozone Air Purifier Expert? Answer questions, earn points and help others
