Question about Hotpoint Washing Machines
How can i empty the water from my hotpoint aquarius wma34 manually
SOURCE: Hotpoint Aquarius WMA34
there is a small access panel in all front loaders.  there is probably a coin stuck in the compartment.  this will stop the water pump operation correctly
Posted on Oct 27, 2007
Richie_asg1
  • 1036 Answers
SOURCE: hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Posted on Nov 05, 2008
john2072
  • 5 Answers
SOURCE: Aquarius Hotpoint WD640 is not spinning
pump problems
Posted on Jan 17, 2009
miket756
  • 2702 Answers
SOURCE: Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Posted on Mar 07, 2010
SOURCE: I have a hotpoint aquarius wmf740 that is showing
Something wrong the pump would prevent the machine draining and generate an F5 code.
http://appliancejunk.com/ge/washer/31-9103.pdf
Service manual above.
Posted on Jun 25, 2010
How do you service the internal water inlet "taps" of a Hotpoint WMA34? Can they get stuck shut through corrosion/lack of use?
Do you hear any noise when it tries to fill with water?You do have the taps turned on correct? :)
Oct 20, 2011 | Washing Machines
Wash machine pump doesnt work
Hiya,
some machines have a filter at the front of the machine it will be right down the bottom behind the trim this trim normally just pulls to open & if so you will see a small circle if you unscrew that some water will come out & if blocked will have some stuff in that you can remove,
Hope this helps
Apr 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, my hotpoint aquarius extra washing machine wma34 drum has stopped turning it is 7 years old. there is power and the water is still going in and draining out but it will not turn. please help.thankyou.
Remove the lower back cover, check to see if the belt is o/k.
If belt o/k,then remove the motor and check the brushes in motor..
If less than 3 or 4 mm long, then they need to be replaced.
Hope this helps .
Jan 06, 2010 | Select Brands Washing Machines
Hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Dec 29, 2009 | Washing Machines
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Aj nide instruchyn HOTPOINT WMA34
Hi.
Log onto -www.hotpoint.co.uk
Then click After sales service,then download user manual.
You can then view this on screen, or print it off.
Please leave feedback.
Nov 01, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Oct 27, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA34 Where to find the motor to change the brushes
DON'T FORGET TO UNPLUG THE POWER FIRST!
Remove the lid and the motor is sat to one side on top of the drum.
Oct 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
