Question about Ford 8N Tractor
Rough idle and no oil presure - Ford 8N Tractor
Rough idle could be several things. Bad plugs, wires, or it might need new points. Could be Carb out of adjustment. No oil pressure could be bad engine or oil pressure gauge. You can try and boost oil pressureby changing your oil with a heavier weight oil (15w40). You can also remove the oil spring at the front of the engine and fill this with oil from a oil can, and put it back in. This acts as a primer. Hope this helps.
Posted on Jan 20, 2013
I have a 2005 chevy Colorado the truck starts and isles but it isles rough, the minute you try to drive it completely dies the engine light is on ,the seatbelt light, ABS light, airbag light these all came...
Idles rough: I would check; EGR value take some starting fluid with trunk running spray engine, if the moter raises rpms you probly have a vacume leak. check fuel presure and fuel filters.change distibutor cap (orclean very good inside and out) may be some oil or someone may have leaded you pencil lead on a lead will make it mis badly.check your wires(plug).Have to go get a checker at store. gl
Mar 22, 2015 | 2005 Chevrolet Colorado
Lost oil presure on a 1999 ford explorer
might just be faulty oil pressure gauge or oil pressure gauge sender unit. I would start by having these both checked. hope this helps
Aug 03, 2014 | 1999 Ford Explorer
1992 Buick rotten egg and rough idle in gear
REMOVE UPSTREAM 02 SENSOR INSTALL VACCUM/PRESURE GAUGE START VEHICLE IF THERE IS MORE THAN 1 PSI EXHAUST HAS A RESTRICTION, CAT/MUFFLER/COLASPED IN EXHAUST PIPE INTERNALLY
Feb 18, 2012 | 1992 Buick LeSabre
Low oil presure light came on briefly but car is idling rough like it wants to die out
Could be a few things. First I would check the oil to ensure the engine is not being starved by oil. That can be done by popping the hood, pulling out the dipstick, wiping it, then putting it back in and pulling it out to get a reading. If it is low on oil that is what will cause the light. However, if the oil level is fine it could be another cause such as bad piston rings, in which you would want someone to check your compression to ensure it is in spec.
Good luck
May 26, 2011 | 2003 Chevrolet Trailblazer Ext
Will intake gasket leak make the lifters tic when first starting
I dont think and intake gasket will cause lifter noise. It may cause a rough idle and or a miss at idle on cold start up . as the engine warms up the miss or rough idle will decrease . As for the lifter noise this could be cause by the lifter bleeding down or poor oil presure . On your model of engine there is no adjustment on the rocker arms for lifter noise . They are a 0 lash type .
Mar 06, 2011 | 2001 GMC Jimmy
Rough idle after oil change and flush cooling
check oil level if it's over filled may give u rough idle
Nov 22, 2009 | 1996 Toyota Corolla
Strong pungent rotten egg smell while driving ,with car cuttingof
You have an oil leak. Chances are the valve cover is seeping oil onto the exhaust manifold. Also the drip lite on your dash means that you are low in oil. So check the oil , add if needed. The bigger problem is that if the car is high miles. You have worn rings which is presurizing the valve cover which is causing it to seep out. It would also explain the oil indicator lite on the dash. If money is tight you just need to check the oil level once a weak and add. Milk it. Otherwise its and engine overhaul, big money. good luck.
Jun 05, 2009 | 1993 Plymouth Voyager
Ran out of gas and now she won't run!
i would say that you have a bad fuel pump or if you have a carb on it the float inside the carb is stuck check these and i'm sure you will find it's one of these.
Sep 06, 2008 | 1987 Ford F 250
Ford 8N Tractor Logo
289 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
