Question about KDS Datamation Systems DS-8BY-BC-820 Multi-Bay Battery Charger for Dell Latitude D820/ D830/ D531 Notebo... PC Notebook
Will a loss of conductor at adaptor side be troubleshooted?
My laptop charger has 18.5 V 3.5 A charger which isnot charging due to a cut at adapter side wire !how can i FIXYA it?
  • Flortzweich
    Flortzweich May 11, 2010
    How close is the cut to the adapter? Also, how comfortable are you with soldering?
This cart has been charging continually, and now shows 3 red lights on the battery charge area. It won't move or charge up.
There can be several reasons why you are facing this issue. You can follow the guidelines mentioned below and check if that work.
-Consider using a different power point and see if that works. If the issue is resolved, then there may be some issue with your previous power point.
If the issue still persists, try the below given steps:
-Remove the power adaptor and Battery.
-Press and keep holding the power button at least 40 seconds.
-Connect the power adaptor without fixing battery.
-Power on the laptop.
-After logon to the windows, shut down the laptop.
-Fix the battery and connect the power adaptor. Now power on the laptop again. Now check if battery indicates correct signal of charging.
If the issue still persists, check if using another power adapter (if feasible) helps. If that helps, then there may be some issue with your current power adapter, it is recommended to contact nearest service center of your laptop manufacturer.
GuruAid.com
Mar 11, 2016 | Electric Mobility Blue Spitfire 1410 ...
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
How to charge massager without charger
You cannot charge a battery without a charger. Why not just buy an adaptor that will do the job?
May 02, 2013 | Computers & Internet
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
My battery is low and when I plug the power cord into the laptop the light that was on on the adapter turns off and my laptop will not turn on. I have a Dell Inspiron 6400
I'm assuming you are using a GENUINE Dell laptop charger designed for this model?
Check the end of the adaptor, if it is the type that has the centre pin, make sure it has not snapped off.
Check the adaptor is putting out 20 volts DC by connecting a multimeter to the outer and inner parts of the DC jack.
Usually, the ac adaptor LED will flash green if there is no charge going to the laptop ("spitting back power"), however, a dead adaptor is often recognised by a lack of the lED light glowing
You can try with a universal adaptor, it will not charge the battery but at least will eliminate the charger or the charging circuit. If this also fails to power up the laptop, then the issue lies with damage to the motherboard
Jan 21, 2011 | Computers & Internet
My Sony Vaio VGN-NR21J Lost power, the DC jack and charger were replaced but still no power to the laptop. What woudl be my options from here? Is there anything else that could be causing the power loss?...
In the first place before the adapter was replaced you should have checked the power to the battery and the battery terminals. Now if there was no power from the adapter/adaptor pins then it is also possible that the wire is hort within and so the SMPS cuts off .
Since the charger was replaced then the voltage at the battery terminals must be checked to see if the power comes into the laptop for charging. If the laptop does not power ON even with a battery in full charge , then it is possible that mother board is faulty and a cost estimate is important before the board can be changed.-- compare with the cost of a new laptop.
Jan 17, 2011 | Computers & Internet
Why does laptop stop working through adaptor after battery flat
Hi There,
Your battery charger/adapter connects to the DC Power Jack to power your laptop and charge the battery. Since the charger/adapter does 2 things, there are 2 "cells" inside it to do those 2 different things. It's not uncommon for one or the other (but not both) to fail. So, often just purchasing a new charger/adapter solves the problem you're having. It appears that yours is continuing to charge but has stopped "adapting" AC current to DC current to power the laptop directly.
Jul 10, 2010 | Computers & Internet
I CONNECT THE CHARGER AND THE CHARGER DON'T CHARGE THE LAPTOP. NOW I I REMOVE THE LAPTOPS BATTERY AND PLUG IN THE CHARGER AND THE SAME THING HAPPENS THERE'S NO LIGHTS, NO POWER AND THE BATTERY IS DEAD....
There are 2 possible problems with your notebook.
1) Adaptor/Charger problem. (common)
2) Notebook power problem. (slight)
To check if there is a problem with your charger.
a) Plug in charger to any wall socket.
b) Get a small solid wire (prefferably insulated).
c) insert one end of the wire to the positive point of the adapter or the inner side of adapter.
d) scratch the outer side of the adapter using the other end of the wire to check for sparks. a spark is highly visible on a 12v power.
e) if no spark is created, then there could have been a problem with your charger.
Hope this helps.
Mar 23, 2010 | ASUS Eee 4G Notebook
My HP G30 530US Laptop won't turn on. This mourning I was using it and was in a rush, battery was 9% and I just closed the screen so it was on sleep mode, got home at 10pm and now it doesn't turn on even...
It might possibly be due to the static charge accumulated on the battery conductors. Not to worry; Please remove the battery of the Laptop and without the charger connected, you need to hold the power button to turn ON the Laptop for 1 min. This will consume all the energy from the battery conductors.
This process is called power drain.
Now connect the battery and connect the AC adapter, now try to start the computer.
I am sure this will help you turn ON the computer.
Mar 07, 2010 | Computers & Internet
KDS Datamation Systems DS-8BY-BC-820 Multi-Bay Battery Charger for Dell Latitude D820/ D830/ D531 Notebo... PC Notebook Logo
60 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
