Question about Hotpoint Aquarius WF210 Front Load Washer
My washe keeps reading either F04 or F05
It is a hotpoint Aquarius super silent which is not not silent WF630 1300 spin
  • Anonymous Mar 25, 2014
    wmfg631 futura
    President:
  • 373 Answers
F04 - Pressure switch jammed on empty while F05 is a blocked filter.
Check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an engineer.
This really is your only option.
Plz rate my solution
Thanks.
Posted on Jan 19, 2009
2 Suggested Answers
  • 20 Answers
SOURCE: my washer keeps coming up with errors
I am sorry this is the best I can do. I would need the machine in front of me to help you further good luckGE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
GE Warranty Management
1-800-626-2224
Monday - Friday: 8 a.m. - 8 p.m. ET
Saturday: 8 a.m. - 4 p.m. ET
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Nov 11, 2014 | Washing Machines
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f16 N/A
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
My washer keeps coming up with errors
You have a right mixture of errors,
F11 indicates that the pump is not working.
F05 indicates that the pressure switch is jammed on full.
F04 indicates that the pressure switch is jammed on empty.
I would start by checking the pump is working o/k.
Next locate and clean filter.
This can be found by removing the rear panel of washer.
Locate and remove large black hose onto tub, remove filter and clean, refit same, make sure hose is on properly.
Test for leaks.
If no improvement, then I think your only option is to call an engineer out as it could become quite involved.
Good luck.
Plz rate my solution.
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Hotpoint Aquarius super silent
Try pressing the "on" and "start" button together for over 5 seconds..............or till the display vanishes. You will tell me the result...............vote too.
Mar 17, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF210 Front Load Washer Logo
426 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
