Question about HP PSC 2410 All-In-One InkJet Printer
Latch on Black Ink side broke and need to find the part to fix it.
How to replace the carriage latch on a HP psc 2410 Photosmart all-in-one printer?
5 Suggested Answers
  • 9 Answers
SOURCE: Latch on 2110 printer broke
Search internet for someone who is junking a 2110. Amazon, E-Bay etc. HP cannot / won't help you. You can try "360 Technologies" in Austin Texas. They do refurbishments on the
PSC2110.
Posted on Apr 25, 2008
  • 160 Answers
SOURCE: replacement ink cartridge not printing
this has various reasons that this problem occurs.but the 1 simple solution is to get it properly work is to uninstall the printer driver and then reinstall it properly.this will definately work.
Posted on Jan 06, 2009
JayBlair
  • 328 Answers
SOURCE: The latch holding the [black] ink cartridge has
Parts not available. Hp will only sell you a refurb unit.
Try ebay or google for a used unit. Also, try itexpressinc.com
Posted on Dec 30, 2009
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
How do I remove the ink cartridge from my HP 2410 printer so that I can replace it with a new cartridge?
Hi milsyr, 1. switch on the printer
2. Lift the blue/gray latch on the cartridge carrier and remove the cartridges you need to
replace.
3. Remove the pink tape from the new cartridge.Hold the cartrige so the label is face
forward,and the words are facing you.
4. Slide the new cartridges into the print carriage.
- The color cartridge goes into the left side of the carriage and the black
cartridge into the right side of the carriage.
5. See that you slide the cartridge underneath the metal bar and then push it down
into place with your fingers.
6. Close the cover on top of the cartridges and make sure the latch is secure.
7. Close the printer carriage door.
8. Press ok on the front of your printer.
- An alignment print will follow.
THANK YOU AND GOOD LUCK!
Sep 04, 2011 | Office Equipment & Supplies
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
How do you replace the ink cartride in a hp 2175 all in one printer
1. Prepare the replacement cartridge by pressing down and back on the top of the protective plastic, then sliding the cartridge out.
2. Set both the cartridge and empty cartridge protector aside.
3. Turn on your printer and lift the access door until it locks into place. The print carriage will move to the center.
4. Once the print carriage has stopped moving, raise the latch to release the empty cartridge. 5. Remove the empty cartridge by pulling towards you. If you are replacing the tri-color cartridge and need to remove the black ink cartridge temporarily, use the empty cartridge protector to hold it. 6. Hold the replacement cartridge by the sides and remove the black plastic tape. 7. Insert the replacement cartridge into the appropriate slot (left for tri-color, right for black) until it snaps into place. 8. Pull the cartridge latch towards you and press down until it snaps into place. 9. Close the access door. -------
You may also download and refer to it's product manual :-
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
and
http://h10032.www1.hp.com/ctg/Manual/bpu73554.pdf
Sep 25, 2010 | HP PSC 2175 All-In-One InkJet Printer
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The latch holding the [black] ink cartridge has broken on my hp psc photosmart all-in-one printer.
Dec 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
I need to remove/replace cartridge,i dont know how?
Hi!
This link guides you on how to replace the cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&product=79477
  1. Turn on the power.
  2. Lift the print carriage access door on the front of the unit, just above the output tray. The print carriage will move into the middle of the access area. Figure 1: Raising the front access doorc00004385.jpg
  3. Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch and then pulling the lower section of the latch forward. Lift the latch.
  4. Grasp the sides of the ink cartridge and pull the cartridge out to remove it. Figure 2: Removing the cartridgec00004386.jpg
  5. Remove the replacement cartridge from its packaging. Touching only the black plastic, remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tapec00004387.jpg
  6. Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage as shown below. Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch). To install the optional photo cartridge (HP 58) for six-ink photo printing, remove the black print cartridge (HP 56) and insert the photo cartridge (HP 58) instead. Figure 4: Inserting the cartridgec00004388.jpg
  7. Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur. Figure 5: Latching the ink cartridges in placec00004389.jpg
  8. Close the print cartridge access door. Figure 6: Closing the access doorc00004390.jpg
  9. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Nov 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp psc 2410 photosmart printer is printing faintly and only bottom half of words in paragraphs. The color is also faint. I have replaced both the color and black cartridges. I have also run head cleand and...
Try taking out the cartridges and blot the bottom of the cartridge with paper towel wetted with warm water.Repeat several times.While the cartdigdes are out, use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridges.
Feb 01, 2009 | HP Photosmart 2410 All-In-One InkJet...
Printer jam
I think you should bring the printer to have Hp check it out. If you think you can fix it, probability is that there is something snagging the inkjet carriage that is preventing it from printing. This is not unusual for HP printers. We have had 2 HP's that did this. We didn't fix it but sent it to Hp who replaced them. The problem was mechanical failure where one of their component broke off and caused the carriage to get stuck. Hope this helps.
Jul 24, 2008 | HP Photosmart 2410 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
Ben Johnson
