Question about Dishwashers
Lamona dishwasher is not filling with water?
When switching on water is not filling. No filters are blocked!
  • 1462 Answers
SOURCE: Ariston Dishwasher LSV 67 AIX wont fill with water pumps out only
somebody is pulling your leg.
messy filter will not cause no fill as long as machine has drained tho it will cause other problems
Posted on Jul 15, 2008
docjohn174
  • 943 Answers
SOURCE: Leak from dishwasher fill funnel
Hi . the air gap is required by law, to have it there.to stop water in the tub, to end up in your water system, which would never happen. try setting the pressure down, and use the dishwasher. it should work fine . turn down taps ,till it stops leaking . should be ok
Posted on Oct 06, 2008
  • 128 Answers
SOURCE: Dishwasher will not start cycle.
OK so you have power, your door interlock switch is working, the intake solenoid is operating.
The issue is that the cycle does not start. This would indicate that your timer is not advancing. The timer tells the machine what to do, when, and for how long. It is not advancing and is stuck at the start of the wash cycle (fill with water). This is not a big issue as a timer is usually easy to replace.
I don't know what type of machine you have so I don't know if is a mechanical or a digital timer.
If mechanical dial type you can simply tun the dial and see if the cycles change. If so for sure you timer is the issue. You simply remove and replace.
Digital is harder to check but from what you say it is most likely your timer.
Shut the breaker off.
Remove the screws from the door frame and from inside the door. Gently remove the control panel. The timer is a simple unit to remove. Unscrew it and disconnect the power supply. Go get a new one from your local parts supplier. Installation is the reverse of removal.
Hope this helps, if so please rate this answer.
Posted on Mar 20, 2010
SOURCE: Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Posted on Mar 22, 2010
  • 10 Answers
SOURCE: Kenmore dishwasher will not fill with water model
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Posted on Mar 29, 2010
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
My GE Portable dishwasher won't fill.
Possibilities:
Water off.
Blocked water filter
Water solenoid valve not actuating
Water solenoid not getting power
Not getting power could be:
Stuck pressure switch,
Programmer not working
Broken lead
Feb 13, 2015 | GE GSC3500RWW Portable Dishwasher
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
How do I change or clean the filter on my Lamona 8362 dishwasher ? I do not appear to have been given a user manual Thanks
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Jul 07, 2011 | Dishwashers
    Feb 21, 2010 | Dishwashers
    Dishwasher leaks at start
    Is the washer not "over filling" due to the water fill vacume pipe and micro switch that shuts off the water once the correct level blocked or restricted due to fatty residue? This could also be one of the washer pipes clogged up and increasing the pressure in the fill tank.
    Jan 20, 2010 | Dishwashers
    Not filling with water to wash
    (1) Fill valve failed, check and replace
    (2) Fill valve filter blocked , take off back supply hose and clean out mesh filter (Turn off water supply first and have a cloth handy to catch water remaining in hose under pressure)
    Nov 05, 2009 | Dishwashers
    My dishwasher won't fill with water. I've checked the float assembly inside the washer and it seems to work fine. I've been looking for the float switch and water inlet valve inside the bottom panel in...
    if hot or both cold and hot fill try to switch the pipes
    if not filling it may be a problem with program and or filter blocked
    check also the pump
    did you check the water is on as sometimes people forget to swith it on
    if the motor has carbons as in the washing machine and if they are worn the water will not fill or better the motor is not going to turn and will not pump in water
    as it is possible the pump may not work
    this will make a sound like emptiness and with air in it
    Sep 27, 2009 | Dishwashers
    Jul 15, 2008 | Dishwashers
    Dishwashers Logo
    174 people viewed this question
    Top Dishwashers Experts
