Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Alerton thermostat programming - Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Turn off honeywell thermostat recovery mode
You would need to know what model thermostat you have...the M# is either on the door or back of the thermostat. So basically you want to utilize the program schedules, but you don't want the thermostat to bring the up to setpoint by the programmed time in the morning? You might as well not have a setback thermostat. Either keep it on HOLD, or program the time for an hour later than your turn on times.
Dec 12, 2013 | Heating & Cooling
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
NEED HELP PROGRAMMING MY RTH230 JUST PURCHASED IT
when programming the thermostat, you must program each day of the week, then sat / sun , next program for morning day anf night, set temp and then push run program button
Oct 18, 2009 | Honeywell Programmable Thermostat Heater
How do I program my honeywell basic thermostat?
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Oct 10, 2009 | Honeywell Programmable Thermostat Heater
I can't program my thermostat
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Please rate my answer!
Mar 11, 2009 | Honeywell Programmable Thermostat Heater
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Hunter programable thermostat
google search hunter thermostat and the model number and manual and it should come up, I found mine with "hunter thermostat 44200 manual"
Nov 25, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
416 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
