Question about Intel MicroStar MS-6166 Slot 1 Pentium III mATX Motherboard - MS-6166
RAM Capacity of Motherboard MS 6166
I've inherited my son's old pc, which slows often to increase virtual memory. I was told increasing RAM size would help. Current RAM is 128Mb; How much RAM will this mobo support please?? Numbers on board are...N1996 MS6166 VER: 1.0 Thanks, in anticipation.
  • George Hart Jun 27, 2007
    Thanks for suggetions. I should have mentioned that the pc is an old "Time" computers build. Will try more RAM.
  • George Hart Jun 28, 2007
    Many thanks to you both for helpful suggestions. I got hold of 2 sticks of 512Mb ram, but system still only sees 128Mb (131072). Will probably get new pc later in year.
I want to updgrade the memory of my personal computer with a motherboard model N1996 MS_6154 Ver: 2.1. but I don't know what kind of memory suited for it. Can you provide the exact model for it?
Posted on Mar 23, 2009
    Scholar:
  • 35 Answers
I have found a manual for your motherboard. The board can support up to 256MB of RAM. The manual will tell you all of the specs you will need to know. http://www.motherboards.org/mobot/manuals/MSI/MS-6166/ Hope this helps. Good luck.
Posted on Jun 27, 2007
  • Darin Odom Jun 28, 2007
    One other thing.
    You might want to increase the virtual memory manually and keep it locked at that setting. I assume you are running Windows 98SE. Take the following steps...
    1. Navigate to Control Panel > System > Performance > Virtual Memory and choose "Let me specify my own virtual memory settings".
    2. Specify the same amount of space for minimum and maximum swap file size.
    3. Make the swap file twice the amount of RAM you have on your system ( or at least the same size as your RAM ).
    4. Reboot your computer.
    President:
  • 2,961 Answers
Unfortunately there are no sites with info on this board, but similair ones can take upto 512MB of ram, but you would be wise trying a matching 128MB stick in the other slot. You will have to visit a computer fair to get hold of sdram or try ebay.
Posted on Jun 26, 2007
SOURCE:
Virtual memory
  1. Right-click "My Computer" and choose "Properties"
  2. On the Advanced tab, under Performance, click "Settings".
  3. On the Advanced tab, under Virtual memory, click "Change".
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click "Custom size", and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click "Set".
Virtual Memory should be roughly 1.5 x the size of your installed RAM in case all data stored in Memory has to be written to the hard drive.
Don't forget to click "Set" after you entered the values, just clicking "OK" is not enough!
Just a tip: You can set the VM to "0", reboot your computer and then defragment the hard drive. When that is complete and you allocate the new VM space, it will reserve a continuous space on your drive, which results in better access times.
Let me know if you have any questions!
Jan 06, 2013 | Computers & Internet
Opening programs is so slow virtual memory running low
which operating system you are using and what is the ram capacity? and onemore thing to check what is your virtual memory capacity. for that
Right click "mycomputer" > properties > advanced >click settings on performance > in advanced tab > increase virtual memory file size.
generally its size is ram capacity * 2 (ex: for 512mb its virtual memory size is 1GB) check that and we can increase the file size also.
Jun 23, 2010 | Compaq Presario 5000 PC Desktop
I can work about 10 to 20 minutes, my computer always say I need vitrual memory and then I have to reboot all day long I have to do this. Can you help me!
If your system lagging due to virtual memory and it shut down than you can increase virtual memory through this step by step:
Step 1: Go to My Computer Properties (Click right button of mouse on my computer)
Step 2: Go to Advance tab.
Step 3: Go to performance setting.
Step 4: Under performance options their is option for advance tab. Go to it.
Step 5: here in last option is to change virtual memory . you can increase manually virtual memory.
Hope this help
Sep 18, 2009 | HP Compaq Presario SR1503wm PC Desktop
Old slow computer
First you can increase your virual memory .
Right click on my computer then go to proeprty then go t oadvanced
then settings of peformance
then go to advanced again clik on change set initial size same as your max size then clcik on set then apply and ok.
Aug 23, 2009 | Dell OptiPlex 740 PC Desktop
Memory upgrade
The RAM limit depends on the OS, for example XP and vista 32-bit can only use 4GB max. you must check the current RAM you have to see if its DDR or DDR2, just take that to your local tech and then he/she/they will let you know. Then just buy some more RAM. **WARNING** you cannot use DDR2 in a DDR motherboard and vice versa
Mar 23, 2009 | Intel MicroStar MS-6166 Slot 1 Pentium III...
Increasing Memory Ram
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
Aug 28, 2008 | Intel Motherboard
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
To speed the computer
upgrade your RAM memory ..........(better not to use different frequency RAMS this decreases the performance) refer to your motherboard manual for this......
install the good antivirus & always keep the virus away ....
so by this you can speed up your pc...
if you are using the windows xp then increase the virtual memory ...
you make the virtual memory double of your RAM size ...
you can do that by going to
control panel>system>advanced>advanced>virtual memory settings> increase the size of the virtual memory for the drive where the OS is installed ....
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 02, 2008 | Computers & Internet
FREEZE
this happens if the rams are of different frequencies have a check with the both the ram frequency ...
if they are different then remove 1 ram ....
& try increasing the virtual memory in the OS ...
if you are using the windows xp .. then to increase the virtual memory just go to
control panel >system>advanced>advanced>virtual memory settings>increase the virtual memory for the drive in which the os is installed ....
increase nearly to the double of the ram memory you use ....
this solves your problem ..
any doubts you can reply me
thank you
bye .....
dnt forget to rate the solution ...
Jun 22, 2008 | MSI KM4M-L Motherboard
Problem with Mercury PI845GVM motherboard
fine ur problem if very simple as u installed 512 mb RAM on ur pc if at possible try to connect on to the other slot and restart the computer and check ur RAM capacity in ur os if it shows as same 256mb then ur have to change ur virtual memory settings i.e memory allocated to the video so configure ur virtual memory as per requirement then free up RAM memory ..
Steps for virtual memory configuration.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Apr 12, 2008 | Intel Motherboard
Open Questions:
See all Intel MicroStar MS-6166 Slot 1 Pentium III mATX Questions
Computers & Internet Logo
570 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
