Question about Dryers
Cleaning linda lbx3ob fan
How to clean linda lbx30 fan blades
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: cleaning the blades
An air compressor would work. It might be a bit too powerful for it.
Those cans of air they sell in office supply stores might work too.
(Previous message was posted as clarification, not solution).
Posted on Jul 14, 2008
voodoomox
  • 1689 Answers
SOURCE: Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Posted on Jan 04, 2009
  • 17 Answers
SOURCE: how to clean blades and/or how to remove fan cover for cleaning
I am certainly not an expert on this field; yet i have done this my self and this is what i did:
MOst fans have clips.
check where the from and back pieces attach. there should be several clips there remove them and voila.
if not there possibly check the centre pice of fan this may have a screw that holds front and back pieces together as well.
Pllease note you will also have to remove the legs from the side of fan as well. if the pic is the same one you have
Hope this helps
Roty:)
Never argue with an idiot
They bring you down to their level
Then they pummel you with experience
Posted on Aug 20, 2009
SOURCE: cleaning of the fans
When I called Seville Support I was told that you can NOT open fan to clean and may not get it together if attempted (glad I stopped when I did!).
You need to use air pressure. After using much of a can of compressed air such as you would use on a keyboard and not getting too far, I broke out my seldom used air compressor which kicked out enough dust bunnies as to block out the sun. Hint: be sure to use outdoors. I'm happy to report both units working as good as new.
Don't have an air compressor? Ask your neighbor, he'll need the correct nozzle to 'blow air' (it comes in handy for many tasks).
Posted on May 14, 2010
Blades moving but cant feel no air
if it is a newly installed overhead fan check the fan direction switch just above the motor
Jun 30, 2016 | Dryers
I am having trouble with loose stitches and my fabric is not being cut by the blade. I have t Cleaned my machine , rethreaded me serger a few times , I have adjusted the tension , I am traveling and I do...
try changing the needles
check the blade to see if it's loose or misaligned or dirty
try wiping the blades,, try using silicon spray or alcohol on them
to clean them.
after you check the blade to see if there loose or not,,
lay a single thread across the lower cutter blade and handwalk the needle through a stitch cycle watching that thread across the knife blade. If the thread cuts clean the blades are sharp. If it moves
forward on the blade, the softer blade is probably dull enough that it needs replacing
Nov 08, 2012 | Husqvarna Huskylock Computerized 910
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Cleaning black wood fan blades for casablanca fan
I have had good results using a product called Scott's
Liquid Gold. It's available in many stores including grocery stores. I started using it to clean up console televisions after repairing them. Make sure you wipe it clean after using it. The residue will attract dust if you don't. It's sort of a "super Pledge"
Regards.
Zashiban
Jun 25, 2010 | Casablanca Fan 6632T Panama® II Weathered...
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
How do I get my cool operator fan apart to clean the darned thing
hi! there,
well! no brand and model,anyway the guard fan has a quick clip lockaround the fan blade,be sure to unplug your electric fan before doing this, unlock clip lock then the fan has a quick handy lock knob at the center of the fan observed loosening knob there is direction arrow in loosening this if i'm wrong going counter clockwise,or take the direction indicated marked on top of knob.
pull out the blade and have it clean if this is a plastic or aluminum clean it with water and spounge/cleanser,avoid to distorsion on fan blade if happen this will wiggle when run again be carefull and on the second guard fan still connected to your electric fan,there is plastic lock nut release and pull out the 2nd fan guard,try to clean this with water and cleanser,the motor assembly with control and stand just wipe it out ,don't try to get wet specially the motor,let all dried up before reassemble.reverse the process to eassembly
Apr 04, 2009 | Dryers
FAN MODEL# 1010 MP
Hello
This would seem to be the motor heating up and cutting out on a thermal overload. Check to see if the motor area is clean and that the fan blades are clean. To clean the motor you can blow compressed air through it. To clean the blades disassemble the cover remove the blade and clean with a mild soapy solution.
May 28, 2008 | Patton Electric Dryers
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
