Question about Mitel Superset 4150 Phone
Waiting for sync
There is a problem with my telephone set which is set is not working and massage appere on display that is waiting for sync.and my set is not working.
please tell me how to use my set?
module no is superset 4150
    Scholar:
  • 95 Answers
This phone is a digital phone and requires connection to a digital system commonly called a "key system". If you have removed it from where it was connected and tried to use it at home or somewhere else it will not work. Most home or normal phone jacks are connected to your local provider directly and is what is called an analog system. The 2 are NOT compatable without an interface device. If it is connected to a key system then thier is a problem with the port on the Mitel keysystem that goes to the jack you are plugging the phone into and you will need a technician to fix/rewire this onsite. Hope this helps you. A manual for your phone can be gotton here: http://www.octelephone.com/4150user.pdf
Posted on Mar 29, 2009
My radio stopped working and just says PHONE with the phone icon on Display. 2006 mountaineer.
Try pressing the phone key on the display. It sounds like you have hit a mute setting for taking or making telephone calls. It is possible that the Sync system is waiting for you to enter a phone number and has killed the radio for the call.
May 08, 2012 | 2006 Mercury Mountaineer
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
I have just bought samsung CLX-3180 Series printrt, scanner and fax. I tried to copy one coloured page, then a massage appered on the little screen, "scanner locked". The scanner and the...
This will occur if the heads are unable to move.
Try to press and hold the stop/clear button.
If that does not work unplug the printer for about 10 seconds and plug it back in.
Sep 26, 2017 | Samsung CLX-3160 All-In-One Laser Printer
I bought several used mitel superset 4025 phones. When I try to plug them in (we have two phone lines in one jack), the display flashes "waiting for sync" and the lights on the phone flash (in succession...
the Superset 4025 is a digital set that is intended to work with a Mitel telephone system. The port must be programmed and connected to a jack to allow the phone to work. The phone is not intended to be used as a home telephone.
Aug 18, 2010 | Mitel Superset 4025 Corded Phone...
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
Massage on display "sync"
This phone is a digital phone and requires connection to a digitalsystem commonly called a "key system". If you have removed it fromwhere it was connected and tried to use it at home or somewhere else itwill not work. Most home or normal phone jacks are connected to yourlocal provider directly and is what is called an analog system. The 2are NOT compatable without an interface device. If it is connected to akey system then thier is a problem with the port on the Mitel keysystemthat goes to the jack you are plugging the phone into and you will needa technician to fix/rewire this onsite. Hope this helps you. A manualfor your phone can be gotton here:http://www.octelephone.com/4150user.pdf
Jan 19, 2009 | Mitel Superset 4150 Phone
Can't fax
You probably have the telephone cord patched into the wrong jack. Make sure it is plugged into the jack marked "line." If the problem persists, try doing this: 1. Unplug the power cord and the telephone line cord. Then wait for 30 sec or so before 1st plugging in the powercord. Wait until the display reads the currently set time, then plug the telephone line cord into the jack marked "line."
Nov 28, 2007 | Brother IntelliFAX 2800 Laser Fax
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Oct 23, 2007 | GE 28111 Cordless Phone
My msi vis p4m800 motherboard don't support two ram
Hi, does your board have 2 diferent color RAM slots?
if it does you must install the RAM in the same color slots.
If not then you have the option of buying a 512 stick of RAM and installing that as a quick fix. The other alternative is to have your board tested by a technician.
Regards mistyman
Oct 15, 2007 | MSI KT4V (MS-6712) Motherboard
Mitel Superset 4150 Phone Logo
470 people viewed this question
Top Mitel Lands Phones Experts
Dustin
Dustin
David Payne
David Payne
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
