Question about Bryant Legacy Series 1 Heat Cool Programmable Thermostat
How do I change the battery in a bryant thermostat?
Screen on Bryant thermostat is blank---Batteries?
Heidi, all thermostats that I am familiar with require AAA, AA or nine volt batteries and are accessed usually be separating the thermostat from the sub-base. Some older stats have a 'ribbon' connector that maintains connection during removal, but most of the newer stats have 'pin' connectors. A picture would help...could you post one with a smart phone ??
Apr 19, 2015 | Heating & Cooling
Send instructions in how to operate a bryant zone plus thermostat
Download the manual at this link... http://www.manualslib.com/manual/22463/Bryant-Zone-Perfect-Plus-A96447.html
Jun 28, 2014 | Heating & Cooling
Changed to lux9100e thermostat and get reversed polarity message on bryant furnace
I think it means that you need to reverse the wires to their respective connections on the thermostat..
Sep 24, 2012 | Lux Tx9100e 7 Day Universal Programmable...
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
Bryant model 661cj018-e ac blowing hot air comprssor does not kick in..my water tray is completely dry..what do i check
Assuming the thermostat is set correctly, the thermostat may be stuck or broken.
I would trouble shoot the thermostat first.
Jul 15, 2010 | Bryant 463AAC008BA Air Conditioner
Change out problem
AIR HANDLERS DO NOT ENERGIZE REVERSING VALVE , THE THERMOSTAT DOES THE JOB THROUGH THE O  OR B TERM TO THE OUTSIDE UNIT. IF YOU HOOK UP TO O TERM AND HEAT COMES ON WHEN YOU SET AC ON THEN SWITCH TO B TERM ON STAT. YOU SHOULD HAVE O TERM ON CONDENSER OUTSIDE AND YOU USE ORANGE WIRE IF YOU HAVE ONE. IF NOT USE UNUSED WIRE IN 6 WIRE STAT HARNESS.
Apr 21, 2010 | Heating & Cooling
Bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
Nov 17, 2009 | Bryant Heating & Cooling
Bryant Legacy Series 1 Heat Cool Programmable Thermostat Logo
266 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
