Question about John Deere 670 770 870 970 1070 Compact Diesel Tractor Technical Repair Manual
Using a 770 for simple work, snow removal. Parked it on driveway, and when I went out in about 30 mins., it won't move. Appears to be engaging the transmission, but simply won't move, forwar
Appears to be going into gear, but won't move when I let off the clutch. No response whatsoever.
philwalker78
  • 605 Answers
SOURCE: Rider loses power after mowing for 30 - 45
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Posted on Jun 01, 2011
richroth
  • 9472 Answers
SOURCE: PTO won't re-engage after mowing
Check the PTO switch for proper closure. This implies that the contact plate may need to be adjusted to ensure that the switch closes. Check the PTO clutch itself by separating the connector at the flywheel. Jumper the black wire to ground. Jumper +12v from battery to the blue wire and listen for a click. I've had some issues with mine as far as the micro switches lining up with their contact plates. As I recall there's also one near the PTO brake band that gave me some trouble. Of course you need to fully release the parking brake, which could have fallen into a light contact mode when you stopped hard like that. Seat, brake, PTO engagement lever and parking brake are all the pssible hangups. Looks like the connector blocks and junctions cause problems, too.
Posted on Aug 22, 2011
  • 6468 Answers
SOURCE: john deere 14.5hp won't move after Put in gear after sitting all winter
the belt fall off?
Posted on Mar 30, 2012
  • 6468 Answers
SOURCE: My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Posted on Apr 13, 2012
  • 13 Answers
SOURCE: transmission won't engage
sounds like its time for a new mower
Posted on Apr 24, 2012
Have a gravel driveway bought a Ariens 24 Snow Thro adjusted skid shoes to lift machine, is the scraper blade also adjustable, it is throwing a lot of rocks?
Yes, they are all adjustable. Loosen the hardware, Find something to use as a shim... a few paint can stirrers.. put them under the Scraper to lift it about 3/8" then tighten the hardware. See how that helps the stone throwing. Gravel driveways are tough for Blowers and Plows...It's best to actually leave snow on the driveway to pack down and form a Base. Then the next snow will be stone free.
Jan 07, 2017 | Garden
Bike won`t start after rain/snow
water may be in spark plug cavity.
Apr 18, 2014 | 2004 Suzuki VL 800 Volusia
1990 Astro AWD. AWD quit working overnight while parked!
AWD vehicles have a centre diff in the transfer case and if there is no traction on the rear wheels then the front wheels will not turn. All wheel drive is not equal to 4 wd which you assume apparently. Check that there is not a diff lock button in the car to lock the centre diff turning it into 4wd vehicle in which case the front wheels would have moved the vehicle
Feb 18, 2014 | Cars & Trucks
1991 eagle talon will crank, but won't start up. 2 days ago I was driving home from work when i turned around in a parking lot and went to my parents house. about a half an hour there i needed to move...
That sounds like the fuel pump may have lost it's prime. Does it have fuel injection, or a carburetor on the engine? How much gas was in the tank while it was parked on an incline? Have you tried any starting fluid sprayed into the air intake hose, toward the engine? Warning! Don't use much starting fluid! Perhaps a one or two second burst, and have someone crank it immediately after you have stepped back at least 6 feet from the engine. If it fires, then it is definitely a fuel delivery problem! But it won't run long like that unless the fuel pump starts working again ... which is most likely when the engine is cold!
Apr 19, 2017 | 1991 Eagle Talon
How do you remove the stereo out of a 2008 nissan xterra?
Start by removing the whole dash board...you'll have a better access to the radio from there. Continue removing the bolts/nuts from the bracket it's connected to...follow all wire connections, and retrace all steps your making. If you trace your steps you won't have a problem. Relatively simple procedure. 20-30 min job
Apr 23, 2011 | 2008 Nissan Xterra
I can shift into any gear but only first is engaged.
One of the gearstick joints has disconnected - hopefully not actually inside the gearbox. Gearstick connects to gearbox via a few rods & joints or a pair of cables in sheaths. Check something visibly moves near the gearbox no matter what movement the gearstick makes.
Sep 09, 2009 | 1999 Volkswagen Beetle
I have a 2006 saturn ion, my daughter has it at college in pennsy, she parked it on a driveway last night before it snowed and she engaged the emerg brake since it was a sloped driveway, today she went to...
Have her try putting it into drive, attempt to go foreward, plant her foot firmly on the brake, put it back into neutral, then try to release hand brake. Other than that, the only thing she can do is to try and warm up brake cables (shielded part near the backing plates) with a hair dryer.(in park, so it dosen't roll over her) This generally happens when water gets into cable shield and freezes Once free, spray some wd40 or other solvent into cable opening and on cables themselves.
Jan 28, 2009 | Saturn Ion Cars & Trucks
2003 grand am
I had same problem. It was fuel pump that needed to be replaced
Jun 25, 2008 | 2003 Pontiac Grand Am
John Deere 670 770 870 970 1070 Compact Diesel Tractor Technical Repair Manual Logo
19 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
