Question about Canon PowerShot SX20 IS Digital Camera
A line has appeared when i look through my lens and it appears on all of my pictures. Worried the camera has seen it's last day, i think my warranty is up too. Anyone have a similar problem?
  • Canon Master
  • 3,287 Answers
What you're likely seeing it a foreign object that is on or has entered the camera lens.
If it is a dark curved line (as opposed to bright line) it may be a hair. It may appear out of focus or in focus depending on where it is and the distance to the focus point of the picture when taken.
This problem can be solved easily by a professional cleaning if you're unable to locate the source & remove it yourself (without the need to disassemble the camera). Cleanings are much less costly than repairs generally, but you should consult a reputable local camera shop and get an estimate for the work - or contact Canon technical support.
Posted on Jan 03, 2013
SOURCE: Camera froze whilst taking pictures, lens stuck.
I had the same thing with my camera. I think it is due to the lens mechanism. It is stuck in one position and thus disabled all other functions on the camera. Try to get the lens un-stuck...
Posted on May 01, 2007
t00nz
  • 4738 Answers
SOURCE: Cannon PowerShot A85
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Feb 18, 2008
SOURCE: taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Posted on Mar 29, 2008
  • 64 Answers
SOURCE: Lens error: restart camera
If you get that message the lens is stuck.
You should take the camera to a repair center.
They should repair it under warranty.
I have seen this problem a few times already.
Posted on Sep 12, 2009
  • 11967 Answers
SOURCE: lens error, restart camera message is appearing...
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 04, 2010
When i take pictures pink lines appear on my monitor and my subject is not clear and sometimes cannot be seen at all. what is the problem? Is it on my lens or on the settings?. help me please...
I think you are photographing in life view. I can't reproduce the error on my D7000. I don' think is has to do with the settings nor with the lens. If you think it has something to do with the settings, try to put the camera back to factory settings, by pressing both buttons marked with the green dots for 2 seconds. One button is on top, the +/- button and one is the Qual button. Be aware that you lose all settings. There are two other possibilities to reset settings, that are less changing, look it up in the manual. One is in the menu recording options and one in the menu personal settings. Both the top lines in the menu's
Oct 18, 2013 | Nikon D7000 Digital Camera
Plz help me- 4 white small bars on my LCD Nikon D5100
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 21, 2012 | Nikon D5100 162mp Dslr Camera 1855 Dx Vr...
Line appears in the screen after photo
If there is the line appearing in the saved/download picture then it can be relative of the following:1. check the lens for dirt or speck of dust that can impose a shadow.2. Possible fault in the optical sensor- the CCD.3.The battery bulge must be checked and if there is lower voltage then it must be replaced but is not related to the fault.4.Fungus within cannot be ruled out and should be checked out and cleaned only if you are equipped to remove the lens assembly.
Mar 12, 2012 | Samsung L700 Digital Camera
Dark spots on appears on nokia n85 8 mp camera
The dark spots is seen in your camera because inside the camera (LENS) some dust/particles may stick.You can check it out by removing the camera and clean all the lens and the housing (cover) which is seen straight to the camera(lens).If not solve the last thing is to change the CAMERA (lens).Good luck
Feb 20, 2012 | Nokia Cell Phones
Dsc-s730 camera . The subject appears very dim/purple when I take a shot. Picture appears same on lcd or pc. My lcd/ribbon cable must be faulty .? I can view old pictures on lcd screen perfectly .
a CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it (remember to rate and comment this answer).
Jun 09, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
My photos come out with lines . Prior to taking the picture, no lines appear. What should I do to eliminate the lines from my photos?
CCD (Charge Coupled Device): one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image).
If seen on both your pc monitor as well as the camera's LCD then it's likely a CCD issue and it's no wonder that it will be more expensive than buying a new digicam. This is why you need to be exceptionally careful when taking care of your camera since most are uber sensitive to being damaged by the slightest miss-handling.
Hope helps.
May 30, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 29, 2011 | Samsung S1070 Digital Camera
We keep getting vertical lines appearing on the photographs we take using the canon powershot a470 one day it was fine the next the lines started appearing no settings were adjusted it hasn't been knocked...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
Dec 26, 2010 | Canon PowerShot A470 Digital Camera
Camera will not start properly and lens is out
Leave the camera sitting with no batteries overnight. Then in the morning install ONLY Kodak AA batteries. I had the exact same problem.
Jun 22, 2006 | Kodak EasyShare CX7330 Digital Camera
Stray line on viewfinder
These lines are normal. See the last paragraph on page 8 of the D70 manual.
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Canon PowerShot SX20 IS Digital Camera Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
