Koss 3370-2 CD player doesn't turn on any more
My Koss 2.1 Flat Speaker CD Mini Hi-fi System has suddenly stopped working. I turned it off, and the next time I went to turn it on nothing happened. I know its not just a problem with the power button as using the remote control to turn it on has no effect either. I know that the unit is still getting power, because the standby light is still on when it is plugged in. Any suggestions or solutions would be appreciated.
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Jul 17, 2017
My daughters had the same problem, try replacing C411 (I think that was the number on the board), its a 10V 1000uf capacitor in what appears to be the 5V power supply section toward the right rear of the main board, that fixed it. On hers the capacitor was swelled up on the end. I checked it out of the circuit and the DVM I used only indicated it had about 500uf capacity.
Posted on Sep 26, 2007
SOURCE: Emerson AV101 System
there is a reset button on the back u will need a ball point pen to push it in and it is very small.
Posted on Nov 19, 2007
SOURCE: dvr 50
Hi I have jamo Dvr50 system and it has been frozen since yesterday. I have power down few times but nothing is happening. It comes on and panel lights up but that is all.
Posted on Nov 21, 2007
  • 4102 Answers
SOURCE: TEAC DC-D2800 Digital Compact Hi-Fi System
check all wires to speaker are correct also if you take the unit apart you might find that their is 2 or 3 fuses inside it might be that one of these has blown.
Also check no dust has over heated anything as this is often the case when anything electrical has been off for a while.
Let me know how you get on ok
Posted on Dec 10, 2007
  • 317 Answers
SOURCE: red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Posted on Feb 14, 2008
I canot get the cd mode on philips mini hi fi system it does work as i have used it before but think i dont have it on the right mode !!
Contact Philips support at:
Mar 08, 2015 | Philips Fwm608/12 600W Subwoofer Mini...
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Hi Thanks for your help, One year old Sony mini
sir i think ypur unit is ok and run correctly... try to check your speaker maybe your speaker got open or burnt... you can test it by swapping your speaker to another unit or you can test your speaker using multitester...just point your selector at resistance test a speaker has 8ohms reading....
the speaker has a two terminal.. a positive terminal and a negative terminal... your multitester has a two lead.. red lead which is a positive and a black lead which is negative..
measure-speaker-impedance-1.1-800x800.jpg Multimeter probe sockets (NL Graphics) Insert the probes of a digital multimeter in the correct sockets of the multimeter. There may be several different sockets for the probes depending on what parameters you're measuring. Look for the sockets marked "impedance" or displaying the ohm symbol. Different models and brands of multimeters will vary in their labeling, so check your multimeter's manual if you're not certain about which one to use.
  • 2 Select the range for the multimeter. Since you'll be measuring fairly low resistance levels with a speaker, choose a range that will encompass readings in the 2-16 ohm range. It's extremely rare to find speakers that will have an impedance outside of that range.
  • 3 Touch one probe to each of the speaker terminals and check the reading. This will be the impedance of the speaker. Record the measurement, and when you're done, turn off the multimeter to preserve the batteries for the next time you need the multimeter.
  • Read more: How to Measure Speaker Impedance '
    if you think this help please rate me thanks...
    Jun 10, 2011 | Sony CMT-HPZ9 Shelf System
    My Sony MHC-EC55 Mini Hi-Fi Component System stereo wont work. i turned it on then it shut off the red light started blinking standby button.. i unplugged it then plugged it back in turned it on ..then it...
    This usually means an overload. On my daughter's system it was because she had extended the speaker wire and where she has spliced the wires the two sides were touching. Try un-hooking your speakers and turn on the system. If it works without shutting off then you can reconnect the wires one speaker at a time. Maybe you have a short in the wire or speakers.
    Mar 02, 2011 | GPS
    I've had my LG Mini HI-FI FB163 for about 2 years, and just recently it locked itself with one of my CD's inside. Everytime I press eject to get the CD out, "LOCKED" appears in the display window...
    Happened to me when we moved it just recently.
    Turn it off
    Press Stop on the system itself (not remote) for 10 secs
    'Unlocked' will read on the screen.
    Turn back on... let it finish reading the cd, then eject should work!
    Dec 24, 2010 | Audio Players & Recorders
    Flat screen tv stopped working suddenly hooked up thru HK230
    Hi there bud , Are you sure you are using the RCA cables correctly? and not just connecting the speakers into the T.V?
    Jan 04, 2010 | Harman Kardon Harmon Kardon SoundStick II...
    My Sony Hi Fi System also turns itself off-when I try to play cDs
    Check if you can see for the belts on the cd deck and change them
    Jul 04, 2009 | Audio Players & Recorders
    Amplifier unit of MHC-W770AV stopped working all of a sudden.
    Start with the simple things first, hunt round for fuses near where the mains goes in. Keep on the lookout for anything that looks burned or broken. If there's no power to anything it will be something in the power supply section.
    Apr 12, 2009 | Audio Players & Recorders
    Televison & Video Logo
    42 people viewed this question
    Top Televison & Video Experts
