I need picture of parts in lea60aw - Televison & Video
  • 8,617 Answers
Send a email request to customerservice@tvrepairworld.com let him know your model and what your needing pictures of. I am sure they can assist you with what you need.
Posted on Jan 04, 2013
Amana dryer lea60aw.when dryer is plugged in and door open, timer is ticking and recently replaced heating element is giving off heat-does the timer need to be replaced? or is it a thermoststat/ etc.?
It should not be on sounds to me like the cent switch inthe motor needs replacement. Common on amana dryer motors, not too hard to fix. See if it slides easy by hand and oil it cleaning out any lint that may have accumulated in the swtich. The job of the switch is to power on the heating element ONLY when the motor gets up to speed and centrifugal force slides out wrights on the switch allowing for power to go to the heater element . Switch stuck most likely, let me know.
Jan 11, 2017 | Amana Dryers
How do I remove the front panel?
AMANA Dryer Control panel Parts Model LEA60AW PLEA60AW
take two side pieces (screws) and the knobs off front and it unclips
Jul 30, 2014 | Amana Dryers
My dryer is overheating. Clothes are so hot you can't handle them. Amana electric model LEA60AW
You control thermostat is not working. Replace it. It mounts on the blower housing. After making sure the blower is not loose replace the stat. It is the only thing that controls the temp. The limits shut down the element if the control stat fails to do so. Them clothes is getting too hot because the 250f limit on the element is shutting down the element. The fuse is not blowing because it is rated for 350f. Therefore with the control stat inoperable the clothes is getting too hot.
Apr 10, 2013 | Amana Dryers
Replaced the thermostat and high limit regulator on my amana comercial dryer lea60aw but forgot to tag wires, starting from the thermostat on the blower, i'm not sure where the wires go to, i have
if i were there i could tell you.just think about it .the wires have to make a path all the way through the element.it should have a wiring diagram in the control panel that will help you trace the path.hope this helps.
Dec 04, 2017 | Amana Dryers
I have an Amana Electric dryer LEA60AW. The heating element was open and I replaced it. The new one shows 10 ohms and the two attached bits show 0 ohms. It still does not heat. There seems to be two...
I believe those two thermostats you are looking at are called limit switches. Both should measure 0 ohms. Sounds like you need to replace the one you're calling the black plastic molded one.
Apr 16, 2011 | Dryers
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana LEA60AW dryer problem??
Check the door switch to see if it is engaging. This will shut down the motor. I usually do this with a plastic ink pen to see if I hear a clicking.
Feb 03, 2008 | Dryers
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
