Belt is not tight - Washing Machines
  • Washing Mach... Master
  • 17,093 Answers
There is a tensioner on dryers. You need to see if the spring that holds the tensioner pulley is loose.
Posted on May 23, 2013
Serpintine belt wont tight ,idler pully is in good shape old belt came off thought it had streached it was almost new replaced it still having same problem.
Are you sure the belt tensioner spring is strong enough to keep the belt tight ?
You should have to move the tensioner to put the belt on, then it should keep the belt tight when you finish.
Apr 19, 2013 | 1996 Ford Taurus
After i installed a timing belt and water pump car is making a squeek noise. Could it be the timing belt is to tight or not installed correct?
verry possible the belt is to tight see if you can wiggle the belt at all if there is a little play then you need to check you pulleys on the motor if there is no play what so ever in the belt then its to tight
Sep 07, 2011 | 1990 Honda Accord
85 chevy celebrity. replaced alternator. that one squealed 2. got another. still hear a squeel. does not squeel when belt is off.
ALTERNATOR BELT NEED ADJUSTING AND REPLACING IT GLAZED. WHEN DRIVE BELT GET GLAZED SHINY CAUSE IT TO SLIP AND SQUEAL.REPLACE ALTERNATOR DRIVE BELT. AND ADJUST IT DRIVE BELT TENSION BY TIGHTEN THE UNTIL YOU CAN PRESS DOWN ON THE BELT IN THE LONGEST RUN. YOU NEED TO PRESS DOWN BELT AND GET A 1/4 TO 1/2 INCH DEFLECTION IN BELT.THE BELT CANT BE TOO TIGHT WHERE WHEN YOU PRESS DOWN AT IT WONT GIVE IN NONE TOO TIGHT, WILL CAUSE PREMATURE ALTERNATOR BEARING FAILURE IF DRIVE BELT TOO TIGHT.
Apr 18, 2011 | Chevrolet Celebrity Cars & Trucks
Can i adjust accesory belt tension without a guage?
Serpentine belts?....yes. Absolutely. Timing belts...no. Drive belts should be tight, but not too tight. If too tight, it could cause noise because of the pressure put on the affected pulley bearings. Too loose can cause poor charging of the alternator, lose of power steering when the wheel is cut to much either way, or squeeling.
Nov 14, 2010 | 2000 Nissan Xterra
I want to change two belts (A/C and Alternator) on my 1999 Mitsubishi Mirage 1.5 car. What steps I am suppose to do.
First, feel the tightness of your belts. You will have to tighten the new belts to the proper tightness. If they are too tight, they will wear the bearings prematurely. If they are too loose, they will slip.
Alternator Belt Removal
  1. Loosen the alternator lock nut.
  2. Loosen the adjuster bolt.
  3. Rotate the adjuster bolt counter clockwise to release the tension on the belt.
  4. Remove the belt.
Similarly for the compressor belt
  1. Loosen the lock nut.
  4. Remove the belt.
5. Install the new compressor belt
6. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
7. Tighten the lock bolt.
8. Install the new alternator belt
9. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
10. Tighten the lock bolt.
11. enjoy life
Oct 12, 2010 | 1999 Mitsubishi Mirage
Is it ok if the belt i get for my car is a bit tighter than the stock. i have upgraded alternator pulley so i got 1 but its really tight and the tensioner is all the way down holding the belt tight ......
It'll be fine....the only thing would be to check it often. A tighter belt will often wear a little quicker than a properly fitting one.....by the way, you want a belt that is tight rather than a loose one. The only problem having an extremely tight or overly tight belt is it can put undo wear on pulley bearings.
May 11, 2010 | 2002 Chevrolet S-10
The belt will not get tight. the pully needs to be
When looking at the belt system the pully would be the one that actually puts pressure on the belt. Adjust it so that it sits closer to the belt when not depressed, this way when depressed it increases the "tightness" of your belt.
Apr 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to put the alternater belt back on?
slacken the alternator bolts then slip the belt on the pulleys,using a long screwdiver behind the alternator,lever it out to tighten belt so that the longest part of the belt between pulleys has 1/2 inch movement(too tight and your alternator will need new bearings very soon...)then do up the bolts,check belt tension after all bolts tight to confirm not to tight/loose.
Apr 07, 2010 | 2001 Suzuki Esteem
My fan belt on my bmw 525 td keeps cumming off nd i dont now haw to put it on and keep it tight eney ansers pleez
The fan/serpentine belt is usually held tight with either spring loaded tension or the pressure put on it by the alternator. If it's the the spring loaded tensioner it has to be pressing against the outside of the belt to keep it tight as it passes around the pulleys.
If it's the alternator that keeps the belt tight, you'll need to find the bolt holding the alternator, usually the top side of the unit. You will notice a curved opening where the bolt passes through, loosen the bolt and keeping the belt tight pull the alternator out away from the engine to put pressure on the belt. Tighten the bolt and check the belt's tension by pressing on it with your finger it should only move slightly, usually less than half an inch. It is important to check the tension after it runs for some time to make certain the belt hasn't slipped or stretched, some stretching is normal as it heats up. If the belt is too tight it can damage the alternator or other parts. A repair manual is also available at the auto parts store to assist you in the procedure average cost 20 to 50 dollars depending on the brand Haynes or Chilton. Hope this helps, good luck
Oct 15, 2009 | BMW 525 Cars & Trucks
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
