Question about Toshiba 57H81 57" Rear Projection Television
Black, Red and yellow triangle in upper right corner of the scrn.
Hello I have a Toshiba 57H81 57 in rear projection TV that is only about 5 years old. Yesturday, A black triangle appeared in the upper right corner of the screen outside of that is a red bar that also is on a 45 degree angle adjasent to the triangle, and finaly outside of that is a yellow bar also on a 45 degree angle, adjasent to the red bar. The rest of the picture looks fine, except the color might be a little off across the top. - I have messed with the convergance and the touch focus, and neither made a difference. The problem occurs on any of the inputs.
- Hope someone can help.
  • burrville144 Jan 26, 2009
    Thanks for the update. I actually did a lot of research and found that it looks like these convergence IC's go bad a lot for these Toshiba TV's. So I got brave and tore open the TV to confirm which model convergence IC's that I had in my unit. I was looking around inside and shown my flashlight through the screen from behind, and the black triangle was there. Super Cheap Fix. There was some black, anti-reflectice sticky paper on the sides inside the cabinet that had come off in the upper right corner. Stuck it back up and whala - Problem Solved. Lucky Me !!!!
    Sergeant:
    Champion:
  • 267 Answers
YOU HAVE A CONVERGENCE PROBLEM IC'S WILL NEED TO BE REPLACED. THE FACT THAT THE LINES DID NOT MOVE WHEN YOU TRIED TO ADJUST THEM CONFIRMS IT.
Posted on Jan 23, 2009
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Big screen TV corners of tv blue and red
I HAVE A 57" TOSHIBA REAR PROJECTION TV. HALF THE SCREEN HAS A BLUE TINT AND THE OTHER HALF IS CLEAR.
Jan 19, 2009 | Televison & Video
Magnavox 51M392H/17
Repair cost 285.00 up to 325 at the most! Replace both STKs 392-020s go to 040s if they are 110s 150s go to 180s.
Oct 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Yellow Haze
What model of set do you have?
Dec 29, 2007 | Televison & Video
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
