Question about Vizio VW37L 37 in. LCD HDTV
Needs a new fuse. Where do I put it?
Where are the fuses located?
  • Vizio Master
  • 8,617 Answers
Fuse is on the power supply board ( where the power cord attaches) some fuses just pop up and the new one pops back in. Be sure the TV is unplugged from the wall before replacing a fuse. Other fuses are soldered in but thats getting rare most just pop out of their holder which is soldered to the board. I am attaching a picture of your power supply the orange arrow is pointing to the fuse which is white.
Posted on Jan 04, 2013
Where is the fuse located at
There is one inside the power supply but you will have to take it out of the pc and then take it apart, a lot of them are soldered to the power supply circuit board. Are you sure it's a fuse problem?, if it is then the fault that caused the fuse to blow needs fixing before you put a new one in, or it will probably just blow again.
Feb 08, 2012 | Dell Inspiron 518 Desktop Computer
How to replace a blower motor fuse
Locate the fuse (owners manual will help with location) pull the fuse out and put the new one in.
Jan 09, 2012 | 2001 Ford Focus
Kid put mom's curling iron in microwave. Turned it on and now nothing. No lights, nothing. Is there a fuse to check? Maybe it is too far gone? Thanks
there is very high voltage present even when disconnected from mains. unplug from mains & leave for 1 hour. remove cabinet. there is a fuse which controls everything usually located near the transformer or where the mains cable enters. check fuse and replace. it needs to be the correct fuse for the appliance
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations
Jan 11, 2011 | Whirlpool MH1150XMQ Microwave Oven
Were is the fuse located in the 3210 e- machine,as i was told it needs a new fuse
Hmm, well that probably isn't correct. If it would need a new fuse it would probably need a new power supply.
May 06, 2010 | E-Machines eMachines W2686 PC Desktop
I dont no where to put the fuse or if it needs one my lights dont work and what kind of fuse
your owners manual should have locations of all your fuses. What year is your windstar
Mar 26, 2010 | Ford Windstar Cars & Trucks
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
I have put in 3 new fuses into the fuse box on my '04 durango and they all blew. Can anyone tell what I'm doing wrong?
What ever the fuse controls has the problem and needs to be addressed first then replace the fuse. Example; if the fuel pump was shorted to ground every time you put in a fuse, the fuse will blow so the fuel pump circuit would have to be take care of first.
Mar 22, 2009 | 2004 Dodge Durango
Put in new batteries and wont turn on
Sounds like protection fuse is blown. Needs to be replaced. Located on DC/DC board (SMT micro factor)
Camera needs to be serviced.
Mar 18, 2009 | Cameras
Kitchenaid icemaker
Most icemakers have a thermal fuse on the black wire feeding them. If this fuse overheats then it will blow to protect your fridge. Check for continuity through the fuse.
(Note that the fuse itself can not be changed. The whole wiring harness has to be changed.)
Nov 03, 2008 | KitchenAid Refrigerators
Vizio VW37L 37 in. LCD HDTV Logo
125 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
