Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Need parts for Jenn Air Model S125
1. Need S125 clock repaired or replaced
2. Need S125 oven control knobs repaired or replaced
3. Need S125 oven door handle parts
4. Is there a replacement electronic control panel for the S125?
  • Trejene Apr 06, 2009
    needing clock for Jenn Air model S125.
  • Anonymous Apr 07, 2009
    need clock and knobs
5 Suggested Answers
  • 26 Answers
SOURCE: Jenn-Air electric range
I believe f3 means a bad oven sensor
Posted on Jan 09, 2008
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
SOURCE: Jenn air oven analog clock
If it's an older oven, forget about getting a new clock. Instead, have it removed (or do it yourself, mark wires and of course discontinue using oven) and try your local parts guy to see if he can send it away to have it rebiult. Best case scenario. Either that or have a technician "bypass" it for you.
Posted on Apr 07, 2008
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a jenn air model jer8850aaw replaced the bottom element and now the element will not shut off what could be the problem?
If the element wont shut off sounds like the oven thermostat control made be faulty, if its a manual knob you use to turn the oven on you'll need to replace it, but if its electronically controlled you'll need to replace what the call the erc or clock.
Oct 31, 2010 | Jenn-Air JER8850 Electric Kitchen Range
Oven door falls open and will not close tight on my Jenn-air Single oven Model #SVE47100w
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
Jul 24, 2010 | Jenn-Air Electric Single Oven
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn Air Oven Repair
HI thanks for the question. you can by pass the clock so the oven will work without the timer. call a tech near you, and ask them to by pass the timer. if i could get the wiring diagram, i could tell you how . its a simple thing to do. thanks the appliance doc. please rate my answer.thanks
Oct 08, 2008 | Jenn-Air Ovens
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenair oven valve knob
In less than 6 years of normal use, 4 burner control knobs on my Jenn-Air free standing gas range, Model JGR8875QDS, have either broken or melted.
If you want to continue to buy Jenn Air knobs, no problem - several suppliers will be glad to provide them for  $10-15, each (USD). Whirlpool's part number for the factory Jenn Air knobs is 74009148, and you can get them from repairclinic.com (#1035396), or PartsSelect.com (#PS2086597).
If, however, you want to try a different set of knobs, hoping to find some that are less prone to break or melt, then it gets a lot more complicated.
Jenn Air/Whirlpool will be no help; they will tell you the only knob that will work is the Jenn Air OEM knob. Parts suppliers won't help you either - no specifications or interchangeability data exists - and they are unable or unwilling to take measurements.
I can tell you the following 3 knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
The following knobs do NOT look like your factory knobs - all three are made from black plastic rather than the (fake) silver metal look of the (plastic) OEM knobs. What I cannot tell you is if the following knobs will be more durable than the factory knobs - but then it's hard to imagine how they could be much worse.
-------- Burner control knobs known to work on the Jenn Air JGR8875QDS gas range --------
1. Whirlpool part number 74008850, made for some Amana gas ranges, will fit the Jenn Air. RepairClinic.com calls it part #1035119, and PartsSelect.com calls Item #PS2086316; it sells for $6-7 (USD). You can see a photo by entering the appropriate part number in the search box of either of the two websites mentioned above. The Amana knob is about a quarter-inch larger in diameter than the OEM knobs, but that does not cause any problems. Of the several knobs I tried this is the only one that tells me what it's made from - "PBT" - or polybutylene terephtalate, a thermoplastic which has a melting point of 430 degrees F and a maximum utilization temperature of 330 F.
2. Whirlpool part number 74009094, made for some Maytag gas ranges will also fit the Jenn Air. RepairClinic.com calls it #1035342, and PartsSelect.com calls it #PS2086544. It sells for about $9 on both sites. You can see it here:
www.repairclinic.com/Appliance-Parts?s=t-74009094-%3d%3d
Like the Amana knob, the Maytag knob is about a quarter-inch larger than the OEM Jenn Air knob.
3. A third knob worth considering is available from AmericanStoveParts.com for $7 each. The front of the knob looks much like their OEM Replica Burner Knob 1104-B (but don't order #1104-B - it won't fit). The knob that will fit the Jenn Air is AmericanStoveParts #1214-025-B. You will have to order it by phone or email because it is not shown on their website. (As of October 2009, none of the knobs shown on AmericanStoveParts.com will fit the Jenn Air.)
Notice the markings on the 1214-025-B are not quite like the Jenn Air markings, with the "HI" and the "LITE" positions being reversed. Also, the 1214-025-B knob I received did not have the white dot at the "OFF" position nor the white ring around the periphery as shown in the photo of the 1104B knob. The total diameter of the the 1214-025-B is 2" - the same as the factory Jenn Air knobs.
While I don't think the front of 1214-025-B looks quite as nice as the Amana or Maytag knobs, the back of the knob appears to be much more robust than on the others. The extra plastic MAY make this one more durable.
Dec 22, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
1,107 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
