Question about Microwave Ovens
Samsung microwave 4444 appear and 5E error
When switch off & put back on works sometimes for a while. Sometimes when dead and touching wiring and rubban wiring going to the asy control it works.
  • ajydumas
    ajydumas Jan 05, 2013
    I worked on the key board's ribbon wiring. The ribbon is bent and glued together. I splitted them apart and isolated them with a piece of paper. Now everything work good except the number from 1 to 6 incl. on the keypad. It's OK we work with that fine.
MicrowaveSvc
  • 9098 Answers
SOURCE: MMV5000BDW Touch panel works intermittently
You have a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung MW1080STA Microwave Oven
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can order Samsung parts here.
You can find your nearest Samsung-authorized service center here.
To find out if yours was recalled, please call Samsung's Service Division at 800-932-3837.
Posted on Nov 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Eterna Microwave stops after a few seconds, must reset clock..
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, this is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
(PLEASE do not be fooled into thinking that the procedure outlined at this link is a "fix". It should only be regarded as another test method to prove that you have a noisy magnetron which must be replaced.)
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
If it keeps failing while the board is in the down position, you either have a very leaky magnetron or possibly another problem.
So you can then get a Ziploc bag and insert a flat piece of aluminum foil into the Ziploc and close it.
Then (with the power off) tape it over the circuit board as best you can, covering it as much as you can, making sure it does not get snagged or punctured.
Then try the oven again. Do not leave this test shield in place as a "fix". It is not safe.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 25, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Touch Control panel of my daewoo KOT-151S
We regularly replace these.
You can send your KOT-151S control panel assembly to us to install a new membrane keypad. The cost would be $64.95.
Or you can order an entire control panel assembly (plastic frame, stainless trim piece, keypad, and control circuit board) for $88.85, which includes return shipping.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 01, 2009
SOURCE: Maytag microwave that has a code of 5E or SE. The
I have the same problem. Did you get an answer? Thanks. l issa
Posted on Jun 21, 2010
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
-se- is displayed on the screen, what does it mean?
Usually means "Sensor error". The problem is usually associated with the circuit board for your touch pad on the front of microwave. More than likely a bad contact/connection on one of the plugs in the back of that panel.
Just type the following in your search engine and the video explains it all. "samsung microwave se (5e) error fix". Hope this is your fix and that you are OK with taking it apart. MAKE SURE ALL POWER IS REMOVED BEFORE GETTING IN THERE!! good luck!
Oct 08, 2015 | Samsung Microwave Ovens
Start enter button not working
If you know how to repair microwaves, see these youtube tutorials:
Fixed microwave number pad
Quick repair GE microwave touch control key panel doesn
Samsung Microwave SE 5E Error Fix
Lg Microwave keypad repair
No light? You can look for more videos or take it to a repair shop
Jul 13, 2015 | Microwave Ovens
What does 5E mean?
The 5E error is a short at the keypad. You can try unplugging the microwave for a while and then plugging it back in. This can sometimes clear the error for a bit.
The solution is to replace the entire control panel assembly. (You used to be able to get either the switch membrane or the control box separately. One or the other would often cure the problem.) If your microwave is under warranty, contact Samsung for repairs. Otherwise, post a comment with the model number. I will try to find the appropriate part number for you. Note: microwaves have capacitors that can supply a nasty jolt. If you are not comfortable with doing the repair, you'll need to get a repair technician to do the replacement.
I hope this helps.
Dec 24, 2014 | Samsung Microwave Ovens
Samsung microwave# smh9187w-x error code 5e-how to repair?
Error code for a shorted membrane keypad switch. Manufacturer suggests unplugging the unit for an extended period of time to see if the control panel will clear the code. If not, then you probably have a defective switch.
Jul 22, 2014 | Samsung SMH7178STD Microwave Oven
Recently purchased this microwave (4-5 months ago) 5E error light comes on. Unplugged worked for short period - lights came on and off, things started beeping and the 5E came back on. Have repeated this...
"SE" means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable.
Since it's under warranty, I would contact Samsung for a free fix. See your owner's manual.
Jul 06, 2011 | Samsung SMH9151ST Stainless Steel 1000...
My Samsung microwave SMH9187W is getting a 5E or SE error code when I plug it in. Unplugging and replugging use to clear it for a bit but now it happens as soon as I plug it in. I am just out of warranty...
Maybe Just Lucky; I removed the front cover above the door by removing the two screws on top of micro. Then I removed the screw above the controll panel and carefully lifted off the panel. I checked all wire connections while plugged in and the SE code changed to 0. I reset the clock and put the panels back on.
Done Loose Wire
Jun 29, 2011 | Samsung SMH7178STD Microwave Oven
5E (SE) error showing on my samsung C106FL micowave oven (2 years old). None of the other keypad buttons are working. I unplugged the oven & re-plugged next morning but still saem result. Pls help.
The "SE" error indicates a shorted membrane keypad.
You can find support from Samsung in India here.
Dec 18, 2010 | Samsung MC5694 Microwave Oven
Entire microwave is dead except LED screen which has a message -- E 5 -- Spoke to Samsung who told me to unplug it for 10 minutes - that dosn't do anything. This is a top of the line over the stove...
From the Samsung FAQ:
For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater (sic) to find your nearest Authorzied Service Center.
It may be a failed sensor.
Sep 11, 2008 | Samsung Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
