Question about Mach Speed Trio Droid 2GB Internet Tablet BlackSilver Hard Drive
Forgot password on Trio 4.3" Internet tablet
Forgot password and need to reset to factory settings.
  • 2,072 Answers
If this tablet is linked to a gmail account, then enter five incorrect passwords and you should get a Forgot Password button. Follow the prompts to reset it.
Alternately you can factory reset.
  • Power off tablet
  • Tab power button then press and hold power + vol down
  • You should get a menu. Choose the factory reset option
Posted on Jan 06, 2013
  • 1 more comment
  • rose martin Mar 11, 2013
    every time it does it it goes back to the robot with a triangle
  • honesty1977
    honesty1977 Apr 04, 2013
    when you get the robot with a triangle hit the volume up button. then you have to use the volume up and down button to go thru the list and tap power button to select the option
  • barbara cottle Jul 21, 2013
    i have worked days and not able to get it to get past the robot with triangle any idea so i not have to toss it in trash not even had it for year and it non usable please help any ideas i have tryed all that i found on the web and noting is working for me thanks
    New Friend:
How to unlock it it keeps coming to a robat with a triangle
Posted on Mar 10, 2013
I cannot remember my password to get into my tablet
hi John.
i think you will have to do a hard reset to sort this out.
Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
More items...
What do I do if I forgot my password to unlock to my tablet? - Trio ...
https://support.triotablets.com/.../201746559-What-do-I-do-if-I-forgot-my-password-to-...
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
or before you do anything go to this link and have some more off a read up.
cannot remember my password to get into my tablet Google Search
Dec 03, 2017 | Tablets & eReaders
I forgot password and now I cant access my tablet.
Here are some options which came from the trio tablet website: What do do if forgot my password to unlock to my tablet
Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
This site also had some tips: Different Hard reset factory wipe methods for Android Tablet
Mar 21, 2016 | Audio Players & Recorders
I forgot the password to my android 9.7 how do I rest it?
Factory Data Reset- Factory Data Reset can be accessed through your settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset tablet and Erase everything.
    1.Settings
    2.Backup and reset on the left hand column
    3.Factory data reset on right hand side
    4.Erase SD card (optional)
    5.Reset tablet and erase everything
Dec 20, 2015 | Mach Speed Trio Stealth Pro Trio Stealth...
How do i reset my password for my digiland 7inch dual core tablet my daughter forgot it and havein hard time resetting need easy way to fix
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process. You will then be directed through the original start-up process as if you got it out of the box for the first time. If you have a Google account and if you stored your settings to Google, your previously loaded applications and saved contacts should start downloading. This is a factory reset, so everything not saved to Google will be lost.
Read more: How do i reset my digiland dl701q tablet when forgot pattern? - How to unlock a digiland tablet if you forgot your password with reset button :: Ask Me Fast at http://www.askmefast.com/How_do_i_reset_my_digiland_dl701q_tablet_when_forgot_pattern-qna8826890.html#q6437553
Aug 14, 2014 | Tablets & eReaders
How do i reset my kurio 7 tablet my daughter forgot the password
factory reset true Recovery mode
vol+/- homebutton last power key
realease home key and - vol when boot
in recovery mode select "FACTORY RESET" enter
"ERASE CACHE" enter
REBOOT DEVICE-
Done
Jan 08, 2013 | Techno Source Kurio Kids Tablet With...
Mach Speed Trio Droid 2GB Internet Tablet BlackSilver Hard Drive Logo
3,371 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
M_Butkus
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
