Question about Drills
Craftsman battery charger no. 981831-002 won't charge batteries
Four batteries-no working charger
  • 32 Answers
SOURCE: batteries don't charge
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Posted on Jul 14, 2009
frankzen
  • 19 Answers
SOURCE: Hi. I need a Sears Craftsman 16 volt battery
www.craftsmancordless.info
Posted on Apr 04, 2009
SOURCE: Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Posted on May 30, 2009
Editor925
  • 285 Answers
SOURCE: What Ryobi batteries p103 or
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Posted on Feb 24, 2011
emissionwiz
  • 75822 Answers
SOURCE: Cannot recharge 18v battery, place
You will need to replace the battery it is defective.
Posted on May 18, 2011
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Drills Logo
588 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
