Question about iLive It082b 2.1-channel Stereo Sound Bar Speaker -used
My ilive remote IT082B only works if i stand about 3 feet away. been on the phone with service and they want to send me a new remote but i dont have the receipt. must be a way to reset??
  • Ralph Sr
    Ralph Sr Jan 05, 2013
    I have an i Live speaker bar. The remote only works if I stand within 3 feet of the speaker bar. iLive service instructed me to reset the remote by by unlugging power, take the batteries out of the remote, press and hold the number 1 key.. Then plug power baqck ion, replace the batteries, new, and depress the power buton. Remote still does not work beyond three feet.
All led lights are going side to side no sound
Make sure you try out all sources using the remote.
Press repeatedly to switch between
AUX 1,
AUX 2,
LINE IN and
FM Modes.
Mar 28, 2016 | iLive It082b 2.1-channel Stereo Sound Bar...
Remote control won't work 10 feet away but if two feet away it works. What gives?
the remote uses light to send a signal to the tv. make sure there isn't anything interfering with the light signal. it could be dirty or the receiver could have dirt obstructing the light.
Mar 20, 2013 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Remote works only when I'm standing really really close to the tv
the fault is probably the infra red reciecer is low gain
this is normally a small printed circuit board.
best to let a service engineer replace it
Jun 30, 2010 | Televison & Video
Pokemon Battle REvolution rental can't start the game
it could be simply that the remotes are not turned on.or it could be that they are not pointing it at the motion sensor or they are standing too close.
I would advise to stand atleast 5 feet away from the screen
note that the blue pokeball is the wii remote pointer
Mar 01, 2009 | Nintendo Pokemon: Battle Revolution for...
Remote issues
i had the same problem and my iPod is a 3rd generation nanno. this system was made before my ipod was made so it doesn't work on the ipod controls, at least that was what the person on the ilive costomer service phone line said.
Dec 26, 2008 | GPX Ilive Travel Dock Black (IC2807BLK)...
iLive It082b 2.1-channel Stereo Sound Bar Speaker -used Logo
93 people viewed this question
Top iLive Televison & Video Experts
Are you an iLive Televison and Video Expert? Answer questions, earn points and help others
