Question about Baby Care
Assembly manuel for wm1848r2
Have the two side boards and head and foot boards thats it how do i find correct hardware and put this thing together??
SOURCE: no directions to assemble a Simmons crib model 2746 76 219
Most of the cribs that you buy have directions on the bottom of the mattress board on how to assemble. They might not be word for word, but its pretty informative. Hey, it does have pictures! LOL
Posted on Apr 02, 2009
co7196
  • 3433 Answers
SOURCE: Pulley assembly not put together belt was not attached properly.
And? The question?
Posted on Jun 08, 2009
Cytherian
  • 124 Answers
SOURCE: I cannot reassemble the base
This isn't an easy part to disassemble. When reassembling, you have to make sure all the tabs line up as well as the plastic parts for the lights. If you're really confused about it and just can't figure it out, you can always try buying a used charging station off "that auction site". Don't spend more than $25.
Posted on Oct 22, 2009
wfservices
  • 262 Answers
SOURCE: Need instructions for putting a walking foot together
http://www.husqvarnaviking.com/us/2821_3079.htm
This is a link to husqvarna site for help..Hope this can help you. Wayne
Posted on Mar 21, 2010
huffman49
  • 235 Answers
SOURCE: how to you assemble it together
put one on then go to the other side and put another on if you put one on next to the other one you will need to go around to other side and put one on there and so on
Posted on Apr 04, 2010
How do I put my foot controller back together, I took it apart because it will not turn off. My model # 66 - AA307535. Controller # 192257
more than likely, your variable resistor in the foot pedal is shot. cleaning is a low probability repair. replace the pedal assembly.
Oct 19, 2014 | Singer Sewing Machines
Presser foot shaft twisted
You can correct this.
Put an ordinary foot on. There's a clamping screw at the back of the part that has twisted round. The head of the screw faces towards the right of the machine (towards the hand wheel). Get a decent screwdriver and loosen the clamping screw a little. Turn the part round so that the sides of the feet are precisely parallel to the slots in the needle plate. Retighten the clamping screw.
Try not to let the misaligned part slide up or down which it will if you slacken the clamping screw too much. It's at the right height when the little lever you use to hold the foot in place has engaged about one third to one half it's length on the lump on the side of the foot at the top.
Apr 04, 2014 | Bernina Sewing Machines
2002 Graco crib instructions . i bought a used 2002 crib and I need to know how to put it together.
ok first thing first ,  some graco cribs and other products from 2002 -2010 are being recalled , so what crib model do you have? second , putting together a crib is very easy , . First , take the head board and stand it up , next find the side railings and one by one put the screw thru the rail and into the headboard , hold it in place untill it is where it needs to be , then put the second railing on , the screws should go thru the rail and into the headboard with the headboard in back of the rails, after the rails are secured then hold the foot board in place untill the screws are fastened into the rails as well , after you do this , then go around and make sure all the screws are tightned, then take the mattress spring and place it inside the setup rails and screw it unto the places alotted for the screws , then after this , place the matress inside and your done....if this doesnt help , please email me at konmon52@aim.com and tell me which model it is
Nov 19, 2010 | Graco Baby Gear
I have my daughter's crib and now I want to use it for my grandson (her son). It's in great shape and we have everything but the instruction manual. It was lost somewhere in between 6 moves. It's a...
Please make sure that a soda can will not fit between the slats as that is the current safety guideline for cribs. As to the sides staying up; if you cannot get the hardware to work, you can drill a nail-sized hole through the side and into the head and foot boards and put a pin through. Later you can put a screw with a wing nut to hold it against little clever fingers. Hope this pertains to your particular model. Happy grandparenting:)
Farmerbear
Aug 30, 2010 | Baby Gear
I disassembled to clean and can't put it together again. Please help
I will describe how to re-assemble a 5886xl, it should be similar...but maybe not. If you mean just the shaving head, not the whole shaver, skip to the bottom here.
There are 2 circuit boards within the 5886xl, the bottom one with display snaps into the top board's multi pin connector, but before, there is a nylon spacer that goes between the boards, alignment is simple, note the cutout for the beeper. If replacing the batteries, you can solder new leads onto the old areas, either by poking wires through, or if having broken off the old battery, onto the flat thin areas left. These may break or come loose during soldering however, so the through-way may be better. Now you can reassemble. There are 2 screws holding the head on, the black plastic piece with the motor attached and the 3 rotating driver sections. The bottom circuit board should fit into the display containing side piece fairly easily. Snap the plug connector into the hole. Screw the 2 screws that hold the motor/head assembly to the display side. There is a retaining piece for the battery in this model, which has a snap that goes into the 2nd circuit board, and the v-wedge holds the battery in place.If using a prebound pack, you can leave this out, and use the small piece of neoprene foam that prevents shaking, that will work. Ok, there are 2 more pieces in this model here...you place a piece that has a hole in the middle (to accept a screw) and 2 clasps...this goes right behind the motor, and over the battery posts. Should snap in. There is another piece that goes over the charge connector, it has 2 holes middle, and 2 to the sides, those at the sides get 2 more silver screws. In this model, there are 2 black pieces, slide them into the sides appropriately. Now place the top section into the shaving head assembly, drop it down onto the back with the connector...should line up just right. There is a screw hidden in the popup shaver section, open that, apply a brown/black screw. The last screw goes at bottom. Attach the head, and you are done.
Now if you removed the retaining clip that holds the individual heads on...place the head assembly on a desk, shaving side down, with any cutout for release button at bottom. You will have 3 screen pieces (which apply to your face)...each has a blade inside. So, if re-assembling, place the screens inside the head assembly. Then insert a blade into each. Apply the tri-circular blade retaining clip piece into the assembly, push gently, and rotate the little round gear piece in the middle while doing so, clockwise to set. Pop the head back onto the razor. The heads should auto-seat once you turn it on. Voila? :)
Jul 14, 2009 | Norelco 7610X Electric Shaver
Brand new tanaka weedeater, ran fine for 10 minutes,
Loosen gearbox at the business end of the shaft. Turn the head slowly until it aligns itself with the driveshaft. Do the same thing with the engine side if this does not fix the issue. It sounds like the dealer did not assemble it correctly. I would take it back where you bought it and have them fix it under warranty.
Apr 04, 2009 | Tanaka 30" Double Sided 24cc Hedge Trimmer
No directions to assemble a Simmons crib model 2746 76 219
Apr 01, 2009 | Simmons Mattress Baby Gear
Manuel
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
May 26, 2008 | Janome L-344 Mechanical Sewing Machine
Crib assembly
i have a crib with the same model number, except it's not cosco..at least i don't think it is. it's dorel. anyway, i have the same crib i believe, and if you say all the parts and hardware is there, maybe you forgot to put on the stoppers at the bottom of the sliding rail. that's the only thing i can think of. hope it helps...if not..try see if you can contact dorel.
Nov 28, 2007 | Baby Gear
Baby Care Logo
Top Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you a Baby Care Expert? Answer questions, earn points and help others
