Question about Dell Inspiron 8600 Notebook
Dell insperon 8600 disc read error
Tried control alt del but wont work
  • James F. Munafo,Sr.
    James F. Munafo,Sr. Jan 11, 2013
    Thanks Chris . You were right on. Didn't want to hear it though.I'm new at this so this is my rating...Jim
  • Dell Master
  • 7,627 Answers
Will it boot? Do a system restore/recovery.
Posted on Jan 03, 2013
Geekman
  • 32281 Answers
SOURCE: A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Posted on Jan 25, 2009
antiochpc
  • 1314 Answers
SOURCE: "Disc read error" Dell Inspiron 1501
This means your hard drive is bad. You need to replace the hard drive and then the operating system.
Thanks and please take a moment to rate as fixya.
Posted on Nov 26, 2008
SOURCE: Crash and Burn dell inspiron 8600 Help
my computer when start I saw the logo of windows, but faster the screen its turned black and dont nothing. I reboot all componet and give me a msg fan are RMP=0, and the hard disk do nothing too.
Posted on Jun 22, 2008
  • 5 Answers
SOURCE: Trying to restore Dell Inspiron 1501 to factory settings.
don't hit ctrl, f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive (usually the D: drive) good luck.
http://virusremoval.vpweb.com
New York
Posted on Mar 20, 2009
ajx13
  • 110 Answers
SOURCE: Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Posted on Aug 08, 2009
Read disk error press ctrl alt del restar
this problem often is fatal.. you could either try changing the IDE cable or the hardisk itself.. if you have spares.. but IDE type is not manufactured already..
Dec 19, 2013 | Dell OptiPlex Computers & Internet
Disc read error press ctrl+alt+del to restart. does not work
Either the disc you are trying to read has an error or your optical drive has failed.
Mar 08, 2012 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Just bought a used dell alienware m15 laptop. I7 intel core I turned it on once... and it booted extremely slow!!!! Than it would not open any apps... or reall do anything besides move the cursor around...
I would do a complete operating system reinstall.
The M15x uses a program called Dell Datasafe Local Backup for factory restores. You can access this program from launching the application from within Windows (it is on the Start Menu), or by using the F8 Windows Boot Options menu. Press F8 after the iniital POST screen (Alien Face), but before you see the Windows logo on the screen. There should be an option to repair Windows, which will launch you into a recovery mode that allows you to restore the system. This option is available even if you have uninstalled the Dell DataSafe Local Backup app from Windows (I did, as its constant polling causes stutterin in Blu-Ray playback). Good luck!
Mar 19, 2011 | Computers & Internet
Dell mini inspiron 910. On boot " a disk read error occurred press CTRL+ALT+DEL to restart " when I do that the same message appears please help me.
I think you have a hard disk error.
Use your recovery disk, or better still Windows Installation disc, and start the boot up using the menu to select "repair system". That will save you the trouble of having to reinstall all of your software and settings.
If it won't work, a format of drive C will fix your errors but you will have to restore all of your dadt.
Hope this helps.
Oct 25, 2010 | HP Mini 1000 Netbook
How do I restore my Dell Insperon 2200 to its original state (configuration)?
press ctrl+alt+del and choose restore from hard disk or factory default some time instead of ctrl+alt+del you try with F8 key
Nov 19, 2009 | Dell Inspiron 2200 Notebook
Jan 25, 2009 | Dell Latitude C400 Notebook
Nov 26, 2008 | Dell Inspiron 1501 Notebook
Believe it or not, this sounds like a memory problem. Anytime you see an error of a page fault in a non-paged area, teh first thing to look for is memory issues. Can you move the memory stick(s) around? Try that first. Microsoft does not handle memory errors in certain areas very well. Sometimes moving the physical sticks around can place the bad memory cell into a less critical area that can be handled better.
Dan
Mar 25, 2008 | Dell Inspiron 8600 Notebook
Start up problem
hi steve,
can you get into the BIOS?
if so, would u make sure the boot orders are following:
1st. boot from hard drive,
2nd, cd rom
3rd, floppy,
4th, network adaptor?
save changes and try restart.
i hope you do have OS installed.
if not change 2nd part to 1st, and 1st to 2nd.
i have gotten the same error with my laptop. my computer was trying to load window from network, through network adapter.
hope this information helps.
Dec 21, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Dell Inspiron 8600 Notebook Logo
29 people viewed this question
Alun Cox
