Question about JVC AV-36F702 36" TV
Wont power up, red blinking light (on timer)
Well my problem with this tv is that one day it would not power up at all, except for the red blinking ON TIMER light. ive tried unpluging it but no effect what so ever. and since in no longer under warranty i opened the back to see if anything was blown, nothing, everything looks normal, no bulging capacitors nothing, so what seems to be the problem?
  • warren poblete Jul 02, 2007
    well i already called jvc thats why im here. they want me to go to a repair center and have them fix it, and usually it would be cheaper to but a new one, thats why.
  • Anonymous Apr 13, 2008
    i have a jvc tv model #av 32d502 when connect to the outlet it comes for a few seconds and shut off my itself the on timer is blinking
    New Friend:
I have a sony 52 inch wega tv the red standby light keeps bilnking. when i power on the tv there is sound but no picture then it turns off
Posted on May 08, 2013
QUOI FAIRE POUR RESOURDE MON PROBLèME IL Y A UNE LUMIERE ROUGE QUI CLIGNOTE ET EN DESSOUS Cé MARQUER ON TIMER , COMMENT FAIRE OUR ENLVER CA S.V.P. MERCI A L'AVANCE ENVOYER MOI LES INFORMATIONS PAR EMAIL S.V.P. CHAYOL@VIDEOTRON.CA
Posted on Aug 18, 2008
    Problem Solver:
  • 16 Answers
In the field of troubleshooting it would in eeprom trouble., replace the EEPROM/Memory to restore in factory mode.. otherwise pogram the EEPROM under the service mode and restore to factory set-up..
Posted on Jan 04, 2008
Refer to the trouble-shooting section of your manual. Usually, with this technology, the lights (Lamp/Temp) on these sets are also used at diagnosis/fault indicators... so, your manual should tell you what a flashing TIMER light represents. If the manual, doesn't provide this information, then ring JVC and ask one of their technicians.
Posted on Jul 01, 2007
SOURCE:
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Worked fine two days ago. Last night turned it on and nothing happened except a red blinking light by the power button on the TV. Unplugged the TV and tried again...same thing - no picture and red blinking...
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 10, 2010 | Toshiba TN55X81 55" Rear Projection...
SAMSUNG 52'' PCN5425R TV WONT POWER ON
when the timer light is turn ON, tv is telling you that lamp will be going out soon, is basically a hour meter, it just reach the limit of hours that tv haves program of use for a lamp and that you can reseted by:
1.- taking the lamp out nad in again, that way tv will detect there is a new lamp. If not.
2.- folow the instructions: http://www.fixyourdlp.com/blog/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter/
Jun 25, 2009 | Televison & Video
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
JVC AV-36F702 36" TV Logo
501 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
