Question about Hotpoint Washing Machines
Hello, I have an Hotpoint Aquarius WMPF 843 Washing Machine (U.K.), but I have been unable to open the porthole door. I have tried to open the door manually, using the plastic tie rod at the bottom front of the machine, but this action does work either. Could you please give me any other suggestions, to solve the problem? Thanks for your help.
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
  • 4 Answers
SOURCE: HOTPOINT F-01 error code
Try http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Feb 16, 2008
SOURCE: hotpoint aquarius washing machine
where is the filter for hotpoint aquarius wma54 washing machine
Posted on Sep 12, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Posted on Aug 28, 2009
barkencoa
  • 3463 Answers
SOURCE: The door catch on my Hotpoint Aquarius WT540
You need to seperate the 2 halves of the door, remove all screws securing the 2 halves together, and prize apart.
You will then see how all the parts are fitted.
Posted on Dec 29, 2009
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Lights flashing and unable to start cycle. Helped once when turned off at mains but not now.
Hi it could be your door lock switch your machine on and wait for 6 seconds and try to open the door if you can thats your problem or may be that the door catch ic worn try and push the door shut with a bit more force
Jun 29, 2011 | Hotpoint Aquarius WF210 Front Load Washer
UNABLE TO OPEN DOOR AFTER WASH
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Apr 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
May 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint aquarius washing machine
May 31, 2008 | Washing Machines
Hotpoint wd63
take door off. outer porthole is just clipped into frame. gently prize out with a small screwdriver
Mar 04, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
519 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
