Question about Behringer Audio Players & Recorders
Where to get parts for Eurolive B315A
I have two older Eurolive B315A speakers and recently a customer leaned on the tripod and the speaker fell to the floor breaking off the twitter plastic assembly. I will need to replace it but don't know where to look for the correct part number.
  • 156 Answers
SOURCE: Peavey floor monitor speakers
you can bypass the volume controller and use the master control. just take out the volume controller and splice the wires from there straight to master control.
Posted on Feb 23, 2009
SOURCE: Double cube fell and separated
Use a Flat blade screw driver to take off both grills. Take both speakers out use a phillips screw driver. Put your fingers in the cube with the protruding grommet, turn the object until you see it protruding its maximum. Next align it with the opening in the other cube and press until you here it click back together. re-attach speakers and put grills back on ..Whala!!!
Posted on Oct 03, 2009
dtci80
  • 125 Answers
SOURCE: behringer eurolive b1520 pro speakers duller than the other
Best and safest is to have a good electronicus check it out.
i've worked on these kind off things, and i assure you not everything can be simply solved without experience, especially when talking about a decent type like Behringer ;)...
Hope this is helpful, and greetings,
Olivier.
Posted on Oct 22, 2009
jhinsincity
  • 616 Answers
SOURCE: I need to take the speaker cabinet apart to check
Remove the four screws that hold the speaker in place, no need to disassemble the cabinet
Posted on Jan 22, 2010
  • 30 Answers
SOURCE: looking for a replacement speaker for my Technics
OK. I suggest typing the model in on EBay and getting the cheapest one there is.
-K.R.
"I know what I know because I know what to do!"
Posted on Feb 07, 2010
Th lights on rare of the speaker are blinking no sound
I had two of these units fail exactly the same way. The amplifier assembly is the failing part.
If it's out of warranty, then you will need to order a replacement. Don't bother with Behringer support, they aren't helpful. I recommend a place called The Tone Garage. They have said they can order replacement amplifier assemblies in about 4 weeks.
Here is the link:
Eurolive B115D Powered PA Speaker
Apr 23, 2014 | Behringer Eurolive B115D Powered PA...
Bottom speakers not working on vs 1520 burning smell has anyone experience this is it the circuitry thats after blowing and can anyone recommend a place to get parts
In my experience, you won't find parts for this anywhere. Behringer has most part numbers custom designed so they can't be found in cross references which means, a technician cannot replace any components accurately with accurate values to accomplish a full repair. I don't recommend any behringer brand equipment to anyone for this reason. The only repair possible here is through Behringer, which is why they did it that way, and also why they price the junk so cheap that you can replace it cheaper than repairing.
Mar 10, 2014 | Behringer EUROLIVE VS1520 High Performance...
Diaphragm replacement parts
Hi
Here's the list of authorized Behringer dealers which should be able to help you out.
-Steve
Find Service Center
Nov 14, 2013 | Behringer Eurolive B212A Speaker
Behringer monitor lost treble
First and formost check the connections and ensure no stray strands between cables are touching, also the surface of the speaker is not been damaged
Jan 22, 2013 | Behringer Eurolive B212A Speaker
Good time! I am Oleg Ivanov, Moscow, Russia. I have a "Behringer eurolive F1520" floor monitors. Was buy its used. HF drivers are fired. When i get install new HF drivers, on filters plate i see...
Oleg Ivanov!!!
If you from Russia read about the decision of the problem with Behringer EuroLive F1520 here (in Russian)
http://forum.plus-msk.ru/showthread.php? t=136317
my e-mail: nata-levich@list.ru
Mar 01, 2011 | Behringer B1520 Pro Eurolive 15" 2-Way...
Have 2 Behringer Eurolive B 215 Speakers and the 15" woofer have no sound coming out only sound thats coming out is from the horns
These have a crossover inside as well as a fuse. If it is blown the link is gone and only the horns will work.
May 13, 2010 | Behringer Eurolive B212A Speaker
The 1/4" TS connection on the back of the Behringer eurolive b212a speaker is not making connection.
I have seen some of the 1/4 inch jacks that had the mounting nut overtightened and it resulted in the riveting of the threaded part to the metal where the wires connect being stretched to the point the riveting came loose, breaking the contact.
The only way to know is to open the unit. Some of the board mounted "plastic" wonder jacks one can't even see without unsoldering them from the circuit boards.
When replacing do NOT overtighten the mounting nut !!!
Dec 17, 2009 | Behringer Eurolive B212A Speaker
Behringer eurolive b1520 pro speakers duller than the other
Olivier.
Oct 22, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
