Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
The bottom is full of water, it makes a noise but it doesn't drain or run a cycle
  • theresa gallagher Jul 06, 2007
    we tried your solution but no water came. we got the repqir man in at the end and found that a ceramic chip was caught in the pump. thank you for your help
    teasie
    President:
  • 1,462 Answers
If no drain, then no cycle. problem is probably that draining is not taking place. check the following: if plumbed in under the sink, remove drain hose from spigot and check no blockage. start any program - all programs start with drain. listen carefully for a low humming noise. if you hear this, it means you have something stuck in the pump impellor - bit of bone, cocktail stick etc. get back to me if you like with what you find
Posted on Jun 27, 2007
SOURCE:
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher sgs43c12 not draining.
The only way to eliminate a pump issue is to actually remove the pump and check it internally, it doesn't take much to block them and also the impellers can come loose, It sound like you are handy with tools so i suggest removing the drain pump and while it's off check the hoses that run to and from the pump for obstructions and make sure the impeller is not loose.
Mar 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx
your absolutely right, remove kick panel and check for leak/ water. if there is none you may need to replace the control
Nov 25, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher fills and empties water but doesnt run any programm
Hello, welcome to FixYa. Can you elaborate on the actions which take place ? Does it fill and just sit idle until eventually drain or do you cancel the cycle manually to initiate the draining ? I should be able to help you with some more details. I will watch for your reply. macmarkus :)
Jun 24, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch Clasixx dishwasher sticks at point when it drains water
you have a clog remove the float clean and replacs,sould work now.
Jul 15, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
857 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
