Question about Refrigerators
I have a whirpool refrigarator with the typical ice maker. The ice make doesn't work, it sounds like it's filing up with water but it doesn't produce ice. This the 2nd time I've had this problem. The 1st time I replaced the ice make. Is there a bigger problem or should I just replace the ice make again?
  • 163 Answers
Hi!!! In order to make ice the freezer needs to be at 5-10 degree if not then you will not produce ice.The thermostat inside the icemaker will not start.If you see the water coming in and no ice then you have to invest in another icemaker.I hate them.Good luck..
Posted on Jan 19, 2009
It quit making ice - water comes out the water side--the dispenser works until bin is empty
some ice makers have an arm on them that stops producing when the box is full and sometimes it sticks in the ff postion
Mar 10, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a ICE2O maytag refrigerator that is 2 years old my electricial board was bad and I had it replaced. The part number is 1290710. Now my ice maker does not work. I have water but no ice. I have...
f there There's no ice Please read this entirely to assist you in troubleshooting this problem. If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If too cold then the ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 01, 2010 | Maytag Refrigerator Icemaker Ice Maker...
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Apr 05, 2009 | Whirlpool Freezers
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
