Question about Vizio VU42L 42 in. LCD TV
TV Turns On, Backlight On But LCD Screen Black, TV Won't Turn Off
The TV was on when the problem first occurred. Just a black screen and the power button will not turn it off. Called Vizio and tried a hard reset but to no avail. Basically, I hit the power button. Then the backlight comes on, but the LCD screen remains black. Finally, I have to unplug it from the wall because the power button will not shut it off.
  • 10 Answers
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
Posted on May 23, 2009
  • 92 Answers
SOURCE: No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
Posted on Jun 18, 2009
phongnv
  • 56 Answers
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Posted on Feb 17, 2009
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
  • 13 Answers
SOURCE: my vizio vx32L turns on but only a black screen shows up
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
RCA L32HD32D no picture
Most likely you have a bad back lamp. Most times when this occurs, the screen will come on for a second or two then go off. Replacing a back lamp isn't a job for do it your selfers. It will involve completely disassembly of the LCD panel.
Jan 12, 2013 | RCA L32HD32D 32 in. LCD HDTV
Tv screen goes black ater 10 seconds
there could be several things causing this, most often it's a defective inverter, or a bad CCFL lamp. You could also have a problem with 24vdc output from the power supply, or "backlight on circuit from the main board. Get a proper diagnoses.
Sep 08, 2012 | Westinghouse TX-47F430S 47 in. LCD TV
I have sound but no picture
oh, so that's your problem. I'm willing to bet you have a picture but just no backlight. Now does the screen come on briefly when you first turn the TV on? Or is the screen black at all times?? Turn on the TV, turn off the lights in the room. Take a very bright flash light and shine it one the screen.I bet you see a dim picture. It sounds like you have a backlight problem. Either you are missing 24VDC from the power supply, 3.3VDC "backlight on" signal from the main board, a bad inverter, or a bad backlamp.
May 12, 2012 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
When you turn it on tv screen turns blue then black
If it stays black and you have sound I would guess your backlight is bad and needs replacing.
You can get get parts for this tv at www.interliquidparts.com
Nov 26, 2011 | Vizio 42 in. LCD TV
I have a 52" westinghouse
Ok you have a lot of things going on here. Your first thing with the lines can be your T-con board or your Signal board or the screen itself. The second thing black screen you would have to be more specific? Is your back light on and you have no image? If that's teh case then I would replace the T-con board or the Signal board. If by black screen you mean there is no light on the screen from the backlight inverter then your BAcklight inverter or the backlight itleft might be bad. and ontop of that you might have the problem that we started with also. You can get westinghouse parts from www.interliquidparts.com You have to order by part numbers so you have to get the number from the actual part of your TV.
Jun 13, 2011 | Televison & Video
ProView PA40JK1A screen just went black one day.
No, There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Proview PA40JK1A 40 in. LCD Television
Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Oct 24, 2008 | Televison & Video
Vizio VU42L 42 in. LCD TV Logo
137 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
