Question about Frigidaire GLWS1649A Top Load Washer
Washer filling over and over
Washer fills agitates then about a min. later fills agitates and does this over and over . If I turn knob to spin it does nothing.
  • lary 1 Jan 19, 2009
    I was filling it on medium load . The water slowly drains when agitating then stops starts to add more water then starts agitating and just keeps doing this over thew the intire agiting cycle.sometimes when I move knob to spin it works sometimes it does not.
  • Stephen Christy May 11, 2010
    How much are you filling the wahing machine? Please try and run the machine with no clothes and let me knoe if the problem continues.
    Steve
  • 5,911 Answers
Check the placement of your drain hose. This may be a simple issue of siphoning. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Make sure you have a sufficient air gap at the top of the drain stand pipe, and that the drain hose is not placed in the standpipe too deep. This can cause the water to constantly siphon out of the wash tub and the washer will continue to fill to try to maintain the water level.
Please let me know if you have questions, or if you require additional assistance. I hope this helps you.
Posted on Jan 22, 2009
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
The agitator will not spin
The problem will be in the pressure starter kindly check whether water stops after certain level and ready for washing,if it is OK means kindly check the wire connections from the operational panel to the motor, in most of the case the timer will not send signal to the motor for that kindly change the operational panel and check it
May 18, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
WASHER WILL CONTINUOUSLY FILL WITH WATER AND WILL NOT AGITATE.
there is a small presser hose that goes from the the side near the bottom of the washer that goes to a switch on the control panel that controls the water level the hose could be stoped up or the switch may be bad
Nov 30, 2008 | GE Washing Machines
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLWS1649A Top Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
