Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Cracked auger gear box in snowblower on DYT 4000 tractor
Picked up a tree branch and cracked the gear box on the center of the auger...need to find the replacement part....thanks
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
  • 33 Answers
SOURCE: tractor will start but will not move
should just be the belt an thats a cheap an easy fix you just need a wrench to take tension off the pulley to put the belt on
Posted on Jan 05, 2009
SOURCE: DYT 4000 Lawn tractor won't start
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
Posted on Aug 11, 2009
mickey813
  • 472 Answers
SOURCE: I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Posted on Sep 30, 2009
mowerman1857
  • 389 Answers
SOURCE: where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Posted on Oct 05, 2009
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
Feb 11, 2015 | Mtd Garden
Can't figure out where to hook the idler spring onto the mower deck on my DYT 4000
look at the picture on the bottom of the foot rest there is a picture there
May 18, 2012 | Garden
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
HALF OF AUGER NOT WORKING
When you got something caught in the auger, the shear-pin probably did it s job and broke, to save the gear box. Remove the old shear pin and install a new one
Mar 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Tractor will start but will not move
Jan 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Ariens Snowblower Repair Facilities
Start buy checking the gear box to see if there is any cracks in the housing if there is then your going to need a new gear box assembly, sometimeswhat will happen is the auger will stop do to an object and the shear bolts don't break while the impeller is still triing to spin causeing the gears in the gear box to break.You can go to www.ariens.com, then go to parts,then click where it says click here to enter Parts Radar, you will need to have your model numberyou can get the break down for your machine which will help in dismantle and puting it back together you will also be able to get the part number for any parts you will need. If you need a new gear box get the whole assembly not the indivisual parts. any other questions please feel free to ask.
Dec 23, 2008 | Ariens Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
67 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
