Question about Home
My Triton T70si shower runs hot but when tryed latter runs cold or only luke warm
Runs cold when switch on,after it has worked ok for the 1st shower
SOURCE: triton t80si shower is very hot even on a low
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Posted on Jul 12, 2010
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
SOURCE: moen posi-temp for shower pressure
There is a little "o" ring in the shower inlet that is designed to collapse as the pressure increases, limiting flow. You can safely remove this and then have un restricted flow.
Posted on Feb 24, 2009
  • 4336 Answers
SOURCE: When turning on the hot water on dedicated hot
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Posted on Oct 09, 2010
When i turn on the shower the water will be warm for one minute and then cold, I have to turn it down and open again to get warm water
Reasons for this: ???
  • bad elements,
    • if one is bad, just replace both
  • bad thermostat or both of them?
  • broken dip tube / cold water mix tube
    • Notice the "RED" in the 1st pic on the left. 90% + of the tank is hot, with a broken tube, 75% of the tank is luke warm to cold.
Check for them. not that difficult of a fix
Mar 13, 2015 | Water Water Heaters
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
Warm water in shower and cold in sink
How long has this been like this? Have you replaced any faucets, or have you installed a new water heater recently?
Jan 17, 2013 | Home
My gas shower is either luke warm or very hot whats wrong
If all the other faucets work, then the problem is the mixing valve in your shower. You will need a new shower fixture.
Apr 10, 2012 | Bosch Water Heaters
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
I have a triton T90xr the water is only luke warm i have changed the element and its still the same
your incoming cold water pressure may have to be reduced if not by the main control valve a pressure reducing valve may have to be fitted
Sep 16, 2009 | Shower Spa Home
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
The unit will not heat any water, press hot but goes straight to
probley heater eliment ? if not megga dear unit buy new one probly cheaper as long as u fit ure self
May 10, 2009 | Home
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
164 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
