Question about Pool & Spa
What direction does a waterway hot tub motor turn
I had the pump repaired i then installed it ,it would not pump any water,i tried to bleed it ,just wondering if by chance the direction can get reversed in the motor.it turns counter clockwise,this is on a waterway pump on a 1998 beachcomber hot tub...
  • 717 Answers
The only way a motor will run backwards is if the motor gets wired wrong.
all motors turn clockwise.
Rod
US Parts Center
888-521-6183
Posted on Feb 13, 2013
  • 59 Answers
SOURCE: I am replacing a waterways pump and motor
on the motor is a label giving the hp and motor specs. there is also a figure on the label showing the wiring for low voltage and hi voltage.
David
Posted on May 25, 2009
gotgeek2
  • 565 Answers
SOURCE: I have a hot tub with three bad motors. The
It's very unusual that 3 motors would go bad at the same time. I'd be more inclined to suspect the controls. Also, it's possible that if the unit is supplied by 240 volts that you may have lost one leg. Losing one leg could still enable the controls, since they are usually 120 volt, but none of the motors would run if they are 240 volt.
You can disconnect the motors and try to run them from a temporary line, too. Might save you some $.
Posted on Dec 31, 2009
  • 8 Answers
SOURCE: qca hot tub pump not turning on
Thats right, hottubbob has got it. Either the pump works or it doesnt. First it is important to know if there is a voltage (most likely 120V) present for the pump. Then what does the pump do? Hum or nothing? If there is a voltage to the pump, wiring or pump is the issue. If there is no voltage at the pump, then is the spa getting power at all? It really is about isolating what component is causing the issue.
Posted on Apr 10, 2010
SOURCE: I need to no how to wire in my balboa pump into m
Have VS501 (NEW) the Control panel at pool top does not display. Also the Blower control turns on the light. Seems like the light control wants to switch between low and high on pump. When I ourchased I also got a 25 foot extension cable for the control panel (only needed 6 more feet) could this be causing part of the problem with the extended cable being to long?
Posted on Apr 23, 2010
  • 990 Answers
SOURCE: jacuzzi hot tub pump. Put new pump and motor in
Check your suction plumbing to be sure it is sealed and tight. Then force some water through the pipe to see if anything is blocking it.
Posted on Nov 28, 2010
Changing hot tub pump flo master power cord to new waterway pump diagram say common white line to port no 1 port no 1 hase an orange wire on it allready wire leads in to motor housing. not sure where white...
DO NOT PLAY AROUND WITH THE WIRING OF THIS 2 PEED.
you can cook the motor in just a few seconds != junk
yes WHITE is common RED is low and BLACK is high
A picture of the connections in the back of the motor is needed for further assistance
Jay the pool pump repair guy in longwood Florida.
Mar 02, 2018 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Our hot tub uses a Waterway Pump. We emptied the water and refilled it with clean water. The pump now just hums... and doesn't pump. Did we do something wrong? Is there a solution. It is 220V. The...
Was the pump working prior to the cleaning or had it been sitting dormant? The motor relies on a starting circuit within it to operate. One of the components can be bad or the pump can be siezed up.
Turn off the power and remove the back cover from the motor. Try to turn the shaft by hand. Is it free to turn? If so, the problem is inside the motor. If not, look for the obstrction.
A local electric motor repair shop can help you if you find damage in the motor and/or pump.
Dec 27, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
How do you remove the impeller from a Waterway Executive 48 spa pump
Take off the back of the motor, put a wrench on the shaft and turn the impeller by hand to loosen. It may be reverse threaded.
Oct 07, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Motor siezed up and will not restart.
Find a local electric motor repair shop and see if the motor is repairable. If not, a new motor and possibly the pump will be required.
Jun 14, 2009 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
My Mustang pool motor by Waterway musts-120 is just humming when it is turned on. It is connected to a timer, but the pump is working fine, just the motor is humming. What do I do? Is my motor toast?
Check your loacl yellow pages for an electric motor repair shop. They may find it is fixable but could at least tell you if it is salvagable or not. Some even carry replacement motors at costs lower than the pool stores.
Jun 10, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Hot tub
go to the manufactures website or just google (the name + service manual/owners manual)
Apr 10, 2009 | Waterway 4 Hp 230 Volt 1 Speed Side...
Pool & Spa Logo
121 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
