I have an Audix D6 that was hastily disassembled, the wires on the microphone capsule were Ripped off How can I repair?
  • 417 Answers
Not to be rude...send it back to Audix to fix or replace. They are somewhat of a liberal company, and usually fix things or replace for free. Just talk to a rep. Now, I am not saying lie to them about it being disassembled.
Posted on Jan 11, 2013
3 Suggested Answers
  • 19 Answers
SOURCE: Works, sounds very thin, level drop
Bad microphone capsule, stuck diaphram. Replace capsule.
Posted on Feb 23, 2010
technical114
  • 1851 Answers
SOURCE: Hi, I have an Audix D6 that stopped working (after
Take it easy, there is no way to damage a dynamic microphone using a phantom power (assuming that the phantom power is correct). In other words try using another cable at another input to check the mic. In the extremely rare case that the mic has a problem there is nothing you can do, just take care and check the phantom power cause I think that the problem is at this stage.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Feb 21, 2011
Hi, I have an Audix D6 that stopped working (after producing nasty popping sounds when connected), I believe because of a bad combination of unnecessary phantom power and a malfunctioning cable. My...
Thanks and regards
Stelios
Feb 21, 2011 | Audix D6 Professional Microphone
I need the wiring diagram for the Audix OM-2
Here's the wiring to the xlr jack. (audix OM2)
Red = 2
Yellow = 3
White = 1
Dec 24, 2010 | Audix OM2 Professional Microphone
Buzz
Try another xlr cable.
If you are using it for vocals/singing, the moistness from your breathe can get on the capsule and cause noise.
It is a microphone that needs phantom power to operate, so check your phantom power supply, whether it's from the mixer/console, or external source.
May 20, 2010 | Audix F15 Professional Microphone
The XLR came apart
The ground (shield) is connected at pin 1. I think that it's the white color cable.
The "in phase signal - hot" is connected to pin 2. It's the red color cable.
The "out of phase signal - cold" is connected to pin 3. It's the yellow color cable.
Your microphone is a dynamic one so there is no need for power supply and no worry about wrong connections.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 09, 2010 | Audix D6 Professional Microphone
Eighth in microphone jack/wire bad
You might want to check the other end as well. Take a ohm meter and check the wires to make sure their is a reading on both.The wire you speak of is called shielded cable and there should be no reading between the sheilding and the center conductor when they are seperated from the capsule. If there is a reading you have a short.To clarify, the outer sheild should read at or near zero when you check @ each end as should the center conductor ( the white ) wire.There should be no reading between the two (the sheild and the white) when they are unhooded @ each end. Also when the capsule is unhooded you should get a reading between the two terminals, if not the capsule is open and needs replacement.
Apr 05, 2009 | Sennheiser 100/500 G2 Series Wireless...
Low Audio Level
I found this happens with a bad capsule.
On the end of the wire you have the microphone capsule. If I remember correctly, the capsule can be unscrewed from the microphone amplifier case assembly. This part can be ordered from a supplier for Sony professional parts.
I have also had the wire go defective, and need replacement. With most of these models, the complete capsule assembly has to be replaced along with the new wire.
If you are not used to servicing this type of microphone, Sony has service reps that can service and test the microphone for you.
Jerry G.
Aug 10, 2008 | Sony ECM-77 Professional Microphone
 Grubhead
Grubhead
