Question about Mobi-Cam Mobi AV Monitor
How do I turn on the screen in mobicam dxr. It is now on audio only.
The monitor is set to audio only. I want to turn on the screen and have both video and audio. How do I do that?
2 Suggested Answers
  • 5370 Answers
SOURCE: my mobicam dxr wont turn
There is a switch on the side of the camera - just move it off of VOX.If the switch is not in VOX mode then turn it to VOX mode.Wait for few minutes, then turn to normal mode and see if turns on and OFF properly. -------- Keep updated.Thanks.Helpmech.
Posted on Sep 10, 2011
Following message displayed on the screen "Connection to module ViCamModule.AudioModule could not be made" kindly help
camera setting for audio is not being picked up for this camera check the setting for audio and see what camera is set on and if not using audio turn the setting off.
Sep 14, 2011 | Bosch DIBOS RACKMOUNT 30 CH 10 AUDIO 32 IP...
Hi. the mobicam keeps turning on and off and the light is flashing?
What does the VOX switch do?
When the VOX function is active, both the LCD screen & Audio turn off and will automatically reactivate when there is
noise in the room being monitored (e.g. baby crying). This feature is useful at night so the light coming from the screen
doesn't bother you and also when running the MobiCam Ultra receiver on batteries since it will extend the life of the
batteries. Note: The VOX function will not work when batteries are low and you cannot change channels on the receiver in
the VOX mode
Jun 14, 2011 | Mobi-Cam Mobi AV Monitor
My Akai DVD Recorder DXR-901 does not operate with remote.The remote IC needs replacement.Where can I buy it in Delhi
hello anilagrawal0
mine dxr 901 dvd recorder remote has become bad
have u found solution for your remote till now
if yes email me at
amitagarwal0002@gmail.com
but do email me as e can together find solution for the remote problems.
Sep 18, 2010 | Audio Players & Recorders
My computer has no audio
I have this monitor.
You need to click on the little audio (speaker ) button then use the + - to advance the volume to its proper setting.
You also need to have the audio jack connected to the correct line out on your sound card.
if you have the audio setting on your computer set to mute, or turned right down, you will not hear sound through the monitor speakers.
double click on the icon in your task bar that controls your sound. make sure it is turned up, then try to the settings on the monitor.
May 03, 2010 | HP w1907 LCD Monitor
My Mobi-cam keeps turning off by itself. What is
This is from the Mobi Camera Manual
Q. What does the VOX switch do?
the VOX mode
Sep 17, 2009 | Mobi-Cam Mobi AV Monitor
I need to open a dxr file in vista??
This is a Macromedia Director file, but the DXR extension is saved in a non-editable, or locked format; may be used for distributing Director files to users who do not need to edit the contents of the Director movie.
Jul 05, 2009 | Macromedia Flash MX
The monitor goes on but no picture. when i turn
RAM problem. Fix the RAM properly in the RAM slot.
May 07, 2009 | Olevia LT26HVX 26 in. LCD Television
Play/open files with .dxr extensions
.dxr files can be opened with Adobe Acrobat
Mar 14, 2009 | Computers & Internet
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Have a nice weekend!
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Mobi-Cam Mobi AV Monitor Logo
51 people viewed this question
Top Mobi-Cam Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Mobi-Cam Baby Gear Expert? Answer questions, earn points and help others
