Question about ASUS K53E-BBR3 15.6in Laptop 2GHz 4GB 320GB DVDRW WiFi
Asus K53E hdmi will not show on tv
When I hook up my computer to the tv through hdmi,the computer recognizes the tv but no picture or no sound.. I've had someone look at the computer and he said everything is the way it is supposed to be
  • 64 Answers
SOURCE: cant connect asus computer to tv via hdmi
Try turning both pc and tv off and connect, then turn both on. Also, make sure your Display setting are correctly configured. Goto Control Panel, Display and click on Settings Tab. If your still having trouble. Try changing your resolution and make sure that you have your TV to the right input. My TV has 4 HDMI 3 RCA 2Component 1 Digital Optical many USBs...can get kinda confusing. The connection should be numbered. Switch inputs with your remote til you get the right port. Then work on getting your pc to display correctly. Set your aspect ration to 16:9 first. Most tv and laptops are set this way. GOOD LUCK let me know how it goes.
Posted on Sep 12, 2009
ChrisBPye
  • 31 Answers
SOURCE: After installing the ASUS EAH5450
The easiest thing to try is change the screen resolution before connecting via HDMI. The process is a little different depending on what operating system you're using.
For Windows Vista/Windows 7: 1. Right click on your desktop and select "Screen Resolution" 2. Slide the bar to change the resolution to either 1024x768 or 1280x1024. 3. Click apply.
For Windows XP: 1. Right click on your desktop and select "Properties" 2. Click on the tab to the far right that says "Settings" 3. Under Screen Resolution, slide the bar to change the resolution to either 1024x768 or 1280x1024. 4. Click apply.
Either of these resolutions should at least give you picture when you reconnect with HDMI. Once you get a picture, repeat these steps and gradually move the slider higher to get a better resolution picture. If you receive the incompatible signal message again, just wait 15 seconds and the previous setting will be restored.
If this doesn't work, you may also have to adjust the screen refresh rate. From the same window that has the screen resolution adjustment bar, click the link or button that says "Advanced." The second tab, "Monitor," has a drop-down menu to adjust the screen refresh rate. Depending on your HDTV, the most common setting for this could be 60 Hz, 70 Hz, or 120 Hz. If none of those values work for you, you should check the manual that came with your TV to check what the proper resolution and refresh rate should be for your computer connection.
Posted on Jun 10, 2011
  • 246 Answers
SOURCE: problem with my asus password
restart your computer and keep hitting "F8" over and over and over until a black screen comes up with a list of options of how to start windows. pick the one that says "safe mode with networking" go to control panel, then user accounts, then delete the password, then restart your computer and see if everything goes back to normal. If so, then go back to user accounts and make a new password and then restart, and see if everything works ok...my guess is that it will. Sometimes it's just weird that way...let me know what happens
Posted on Jun 09, 2012
joelwilcox
  • 1274 Answers
SOURCE: My ASUS F5SL laptop doesn't recognize my flash drive. It recognizes my mouse, my mp3 player but won't recognize my flash drive pen or my psp. Can, please, someone help me? I'm running Wind
have you tried different usb ports? hit the windows key and the R key at the same time and type diskmgmt.msc and go into disk manager and see if the flash drive shows up in the list of disks installed.
Posted on Jun 26, 2012
  • 233 Answers
SOURCE: My AC adapter (ASUS K53E) will only charge the computer when it is at a certain angleor when i push really hard.
It is most likely that your laptop dc jack is loose or dead. Just replace it or repair it. If you are good at computer, you could do it by yourself as the following instructions:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Posted on Oct 31, 2012
Cant get sound via HDMI HOOK UP TO SONY TV
Some HDMI don't carry sound signals and you have to hook up the headphone jack to the TV with a headphone to RCA adapter.Sometimes you can go to control panel on your computer and turn on the HDMI sound but sometimes not.
Apr 18, 2015 | Toshiba Computers & Internet
How do I hook up my asus CN60 box. TV don't show anything on scree3n
Did you switch your TV "Source" input to match the HDMI port that you connected the CN60 to? It will not automatically go to it.
Dec 26, 2014 | ASUS Computers & Internet
Computer wont detect hdmi1 on tv
HDMI 1 and 2 are physical sockets. If you need it on HDMI 1, plug it into the HDMI 1 socket.
Feb 27, 2014 | Computers & Internet
Connection to PC
I have had the same problem. If you have a VGA cable shown at the bottom. You can hook that into your laptop into the TV. The slots look like a blue incovering. You can also look at the image below that one for more additional help....
images?q=tbn:and9gcsiv-gyi4jh5l6apvblrydzbiwzndoskvj3ytpifllclwa1qmks
images?q=tbn:and9gctjzjmvlnbu_yfg04yh87cl2mau36aexgpvkl7rwz0yczn0azmwaq
Jan 29, 2014 | LG RZ23LZ55 23 in. LCD Television
Hdmi audio working not video
Have you tried a different HDMI cable? Could be a lose connection in the cable.
Oct 03, 2017 | ASUS Q500A-BHI5N01 Laptop i5 2.5GHz 6GB...
Have hooked up HP Pavivillion PC with HDMI cable; get no audio, picture is fine. How do I get the audio to the TV??The TV is a new Insignia NS-L37Q-10A.
Plug in the HDMI to the TV and set the TV to HDMI input. Go to the Vista Contol panel on the PC, to Hardware & Sounds, then Sound.
The control panel will show the computer speakers as the default hardware. Highlight the HDMI icon, click the Default button! That's it: obvious when I realized "default" was not "return to default settings", but setting the default device. Duh... always simple once you see it.
Thanks, Rick Russell
Nov 13, 2009 | Insignia LCDTV26 26 in. Television
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
TV does not always recognize the DVD player
that's a firmware problem where your tv's firmware does not handshake with your dvd's firmware. This could be from your dvd's software being to old for your tv to understand it. HDMI (TDMS Technology) still has Alot of catching up too do with 3rd generation tv's. Alot of HDMI devices still have the first gen software loaded into them. So a tv after 2005 won't work with HDMI from 2003 (1st gen). Most tv's made after 2007 have software that's "backward compatible" so they will work with first gen HDMI.
How does your tv perform outside this problem???
Feb 10, 2009 | Samsung PN50A550 50 in. Plasma TV
No picture, but sound
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Dec 28, 2007 | Toshiba SD-5000
ASUS K53E-BBR3 15.6in Laptop 2GHz 4GB 320GB DVDRW WiFi Logo
323 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
