Question about Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
The washing machine fills and agitates, but completely stops when it comes time to drain. So I do not know if it will spin because the timer knob stops when the wash cycle (agitation) reaches the ''spin'' mark on the dial. Once it stops, no draining occurs and the soapy water just sits there. I've pulled out all of the wet soapy clothes and still no action. It will, however, still fill and agitate if I return the dial to the start postition again. It just keeps on stoping in the same spot (''rinse'' mark on the knob) with no draining. after rinse washer wont drain and spin
  • Anonymous Mar 26, 2014
    it will not drain or spin out after rinse cycle it will slowly spin one way stop and then spin the other way continously
    Problem Solver:
  • 20 Answers
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 517 Answers
Check the pipes from the drum to the exit ...make sure there is no blockages ..if no blockages check the pipe
Posted on Nov 24, 2015
2 Suggested Answers
danromarris
  • 101 Answers
SOURCE: machine fills and agitates, but won't drain
It sounds like you pump is clogged. If there is something stuck in your pump the motor can't spin it to drain the water. If that is the problem then it's easy to fix. Simply clear the pump and put it back on, just make sure to clamp off the hoses to the pump with hose clamps or you will have water every where. If that is not the problem though then it means that your timer is bad and that is a little more expensive. Try the pump first though and hope that that is all it is. If not, like I said, you will need a new timer but most likely your pump is just clogged with something that is causing the pump motor to not spin. It could be a coin or a hair pin or even a sock or something. Good luck and let me know if you have any other questions.
Posted on Jan 21, 2009
Kenmore 800.agitates and fills the same time
no usually the water stops coming in before agitation starts. check the water level sensor it might be plugged with soap crud
Oct 28, 2017 | Washing Machines
Kenmore washer model #111092581200 won't stop filling and won't agitate
Please recheck that model number. It is coming up as a microwave.
Oct 31, 2012 | Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Jan 16, 2009 | Kenmore 22422 Top Load Washer
Washer clothes
Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
2,991 people viewed this question
Sal De
fordexpert
Robert Rankin
