Question about Acer AL1916B 19" LCD Monitor
No power the monitor use to cut off for a few seconds and come back on sometimes when first powered up then after about say 4 to 5 hours of use it would switch off at first i suspected the timer so I set it to max time till it would go off.it still did the same .so it could be the 4 capacitors close to the heatsink.but now the monitor would not power up, no power lightorange or green. so is it the capacitors that have expired and cause a break in the circuit board or the monitor itself has failed got just over one year use out of it.cant really buy one any time soon say till the new year.
  • robinh han Jul 20, 2007
    the problem looks like its on the main board.the part is lable U 406 it looks like a transitor can't make out the number on it cause its burnt out and that part or main board is hard to get tried the company already. can you give a site where I can purchase components off the net.
Well Good news I got my monitor to work once more As I suspected it was one of those surface transistors it had burnt out on the mainboard.well I searched and searched and could not locate that part so I called the company lets say I just blew more money no help but the tech did try.WEll got the part or one simular cause as it is it would cost to high to send it to the company so I had nothing to lose. so the same time I looked on any circuit board I could get my hand on when I came on a agp card mmx4400 128mb that had stop working and bam there it was the part or one that might work so i tried it and it worked its been working now for over a week now and it works better no more shorts or cut off. so hope this might help someone out there. BAT21
Posted on Aug 26, 2007
  • Acer Master
  • 12,061 Answers
Yup replace those stinkin Caps ya B good to go .. Have had this happen heaps in the shop.. damn designers couldn't design a subway sammy ... lol
Posted on Jul 15, 2007
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3. Unplug power cable from LCD, Once power cable is unplugged from LCD, press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
Oct 06, 2008 | Samtron Computers & Internet
IIYAMA PL431 TFT cut-out
Depending on the make and model of TV, there's sometimes a menu option to set the display. This is often only accessible via the remote control - somewhere!!!
Waiting for your reply..
Feb 23, 2008 | Computers & Internet
Computer was on, screensaver is from my photo file - it was running. I moved the mouse to get back to the screen I had previously been on, walked away for a minute, came back, the screen was black. ...
Windows 8 especially and sometime Windows 10 may have a black screen during an update for over 15 minutes with no indication that anything is happening.
Try complete power down by holding the power key for 10 full seconds. Consider unplugging power for a few seconds after that as well.
Re-connect power, press power button to turn on the computer then if the screen goes blank, give it a half hour before looking for another solution... it may come back to you.
Nov 06, 2017 | Sharp LL T19D1-B (Black) 19" LCD Monitor
Screen goes black
More likely to be in the power supply/inverter baord: http://www.lcdrepair.us/E228WFPc-inverter-power.html
Look for bad caps first, but it can also be in the lamp assembly, you will need lamp tester and inverter tester to verify that.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | Dell E228WFP LCD Monitor
Picture goes black at random intervals
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
Monitor loses all power and blackscreens
I've experienced the same problem in a large environment and found that capacitors within the pc itself were swollen...replacing the motherboard solved the issue.
Dec 09, 2008 | Computers & Internet
Monitor goes off after a few minutes of use. when pressing the on/off button, sometimes will turn back on. if left alone will turn back on after a few minutes. when computer is off, sometimes will turn on...
1.check power supply section any dry points
2. To replace all electrolatic capacitors in Power supply
3.Check Connectors Properly connected Or Not.
4.Replaced Microswitches in Front pannle.
Oct 06, 2008 | ViewSonic VX910 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
