Question about Video Game Consoles & Games
I have a DSL-6740U wireless roter and i can't connect my XBOX 360 to XBOX LIVE
It worked prefcet untill i got the new router now when i turn my xbox on the router immidately stops the internet but the wireless still working without internet connection in the xbox or pc
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Posted on Sep 26, 2007
SOURCE: PC Selected - Failed
Click Start, click Run, type cmd.exe, and then click OK. a. At the Command Prompt, type the following text all on one line: reg add HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS\{4D36E967-E325-11CE-BFC1-08002BE10318} /v UPPERFILTERS /t REG_MULTI_SZ /d PartMgr /f You receive the following message in the Command Prompt window, to indicate that this command was accepted: The Operation Completed successfully After you done that restart and download xboxxpsp2-enu.exe...and you should be good to go if your firewall ports are open 1900,10280,10281,10282,10283,10284 dup and 2869,10243 tcp good luck Restart the computer. 4. After the computer restarts, you can run the Media Center Extender for Xbox 360 application
Posted on May 07, 2008
  • 7 Answers
SOURCE: how do i connect to xbox live with a router
OK well there is a much easier way of doing so, if you have a laptop. You can go to
  1. GO to my network places
  2. Click view network connections
  3. Click on the wireless connection bar
  4. Click on properties
  5. Go to the advanced tab
  6. Check the 2 boxes
  7. Press ok
Now your laptop will chare the connection with other devies. So you can hook the 360 directly to the laptop and it will work.
Posted on Jun 17, 2008
SOURCE: xbox live not working
XBOX SHOW E68
Posted on Jun 27, 2008
  • 9 Answers
SOURCE: xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Posted on Nov 10, 2008
DSL-6740U VDSL modem Dlink slow wireless connection
Sounds like the network card on your computer can't handle any speeds higher ... Replace network card
Feb 20, 2013 | Computers & Internet
How do u connect an an xbox 360 to xbox live
You need either a blue Ethernet cable to connect the Xbox to an internet outlet or a wireless router. If you use the wireless router, hook it up to your computer so it broadcasts a signal, then, depending on what Xbox you have, if its the new 360 slim you won't need a wireless adapter, you search for the signal, then connect it. If you don't have the 360 slim, then you need to buy a wireless adapter and it plugs into the back of the Xbox.
Aug 24, 2011 | Microsoft Xbox 360 Console
I bought a new DSL-2642B Wireless Router and Modem but it won't let me connect to Xbox Live, the solution that the Microsoft Solution thingy game me was to change the MTU settings, any idea of how to...
In order to connect to Xbox Live with a Wireless Modem and Router, you will need a Xbox 360 Wireless Adapter. You can get a Xbox Wireless Adapter cheap on eBay, or you can buy it Microsoft at Gamestop. http://www.gamestop.com/browse?nav=16k-Xbox+360+Wireless+Adapter
To find your MTU Settings, follow these steps.
1. Click on 'Start'
2. Click on 'Run...'
3. In the bar, type CMD, and hit enter.
4. A black box should appear. Type "ipconfig" without quotation marks in the field.
5. Your IP Address, Subnet Mask, and Default Gateway codes should pop up.
6 Go to your internet browser and type you IP Address into the URL box.
7. You should find MTU settings, and you can set them to your desire.
May 28, 2011 | Microsoft Xbox 360 Console
How to get an internet connection for xbox live
Hello award ward,
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible
with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
michael34
Mar 09, 2011 | Microsoft Xbox 360 Elite Console
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
I want to connect my xbox 360 to xbox live through my dsl-200 modem but it only has 2 ports, what do I do?
D-Link routers empower gamers to easily connect their Microsoft xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to xbox Live.
  • Click here to upgrade your firmware.
  • Click here for xbox Live setup instructions with a router.
  • For xbox Live support, please visit www.xbox.com.
  • Thumbs back!
    Nov 07, 2010 | D-Link DSL 200 (DSL-200) Modem
    Have one ethernet for computer want to use xbox live so i take out the ethernet from computer and put it in xbox unplug wait plug back in turn still will not connect red x for modem
    You should get a cable/dsl router/switch or wireless cable/dsl router/switch and put it between your Modem and network nodes (IE your computer and xbox 360)
    So it is modem to router wan port
    Xbox 360 to router lan port
    Computer to router lan port
    You can purchase one cheaply at best buy
    look at this link
    http://www.bestbuy.com/site/olspage.jsp?skuId=8741365&type=product&id=1202648529130
    Jul 29, 2009 | Microsoft Xbox 360 Console
    Cannot connect xbox 360 to wireless router
    If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
    Dec 29, 2008 | Linksys Wireless-G WRT54G Router
    Xbox360
    Hello taz1028,
    In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
    Sincerely,
    Agent Xiong
    May 31, 2008 | Microsoft Xbox 360 Elite Console
    Xbox Live Connection Interrupted
    Ok, all you have to do when it comes to buying a wireless reciever is to buy the microsoft brand one made for xbox live. (100 dollars) Once you have this;
    1. turn of the xbox 360 and plug in the adapter.
    2.turn on the 360 and go to the network settings option
    3. this should bring up a page offering a view of you ip address and ect., go to the bottom link (3rd), and select it.
    4. this should give you the option to select your wireless network, then connect to it and test the xbox live connection.
    5. Once you pass the test, continue to hit "b" until you are back at the very main menu and begin playing!
    Mar 12, 2008 | Microsoft Xbox 360 Console
    Video Game Consoles & Games Logo
    49 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
