Question about Frigidaire ATF6000ES Front Load Washer
Washer have a litter water come in
Wash won,tcleanthecloths
  • Official Brand Answer
  • 4,342 Answers
Hello Morris Daniels - Are the house valves fully turn on? Is the hose kinked or pinched? If not, then it sounds like you have an issue with the water pressure and possibly will need to replace the pressure switch. First try checking water pressure at another faucet in the house. Wait until water supply and pressure increase (water pressure for washer must be at a minimum of 30 psi). Straighten the water inlet hose if it is twisted or kinked. If any proves to be ineffective, contact a professional to move forward accurately.
Posted on Jan 09, 2013
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
My spin cycle on my ariston aib 16 is locked as OFF, how do i turn it on
You have given little information.
Check is not littered filter of the pump adown washer machine.
Needs information that works?
It Is Flooded and meets water? Works die out?
Works the pump?
Apr 16, 2014 | Indesit W 123 Front Load Washer
My RCA Opal M4202, was washed in the washer last will turn on, is there anything I can do save it?
Hircw51...
If you ever find that you have to deal with a wet device, don't just abandon it.
Instead, try the following method to repair the water damage:
DO NOT TURN IT ON!!
Take it apart as much as you can. Take out the battery, the memory card and whatever else can be easily disassembled. (Just make sure you can put it back together.)
Store the parts in an air-tight container covered with either dry rice, silica gel packets or kitty litter. These will absorb the moisture from your electronics device, leaving it water-free.
If no rice, gel packets or kitty litter are available, try using a vacuum to **** the water out. Do NOT blow-dry the parts, it will only force the water farther in and cause more damage.
Free answer...Please take time to rate me.
Jul 07, 2011 | RCA M4202 MP3 Player
The washer will not drain I cleaned the bottom drain out and it was full of something that felt like kitty litter (it was not kitty litter) something fell apart when I was washing. I attempted to run a...
Your drain system is clogged with debris. Remove the filter from the bottom left door and look straight back inside the drain system, you will see more debris inside. Do not use a sharp object to remove the debris or you will puncture the rubber bellows. From the back of the machine, remove the back cover. At the bottom of the tub you will find a rubber drain hose that leads from the bottom the tank to the drain filter. Using your hand, gently squeeze the rubber drain hose to "massage" the leftover debris inside. This should help clean out the debris. WARNING: This will cause a major rush of water to come out so be prepared. Good luck
Jun 18, 2011 | LG WM2016C
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
WONT DRAIN HAS ERROR CODE F5
Faulty owerflow pump or was littered discharge of water
Jan 08, 2011 | Indesit W 123 Front Load Washer
Water not coming into washer
water will not enter the tub. Replaced water inlet valve. Checked inlet voltage 120v. No outlet voltage at water inlet valve.
Jan 07, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
246 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
