Question about Samsung "scx-4623f multifunction laser printer"
My samsung printer does not show up in scan and fax manager
  • 25 Answers
Try to download the driver from the website?
Posted on Jan 03, 2013
Language on display is corrupt
Dear
Pl. down load the samsung easy printer manager and do the setting.
Printer Support SAMSUNG India.
Thanks.
Mar 05, 2015 | Samsung ML2855ND USB 2.0/Ethernet...
How do fax with Setting Up the Hardware for Faxing on samsung xpress c460fw printer
Dear connect the telephone line to the socket marked as LINE at back side of the printer,also you may connect an extension phone to the socket marked as EXT.
Put the document face down ward at platen glass and face upward in the ADF.
Select the key marked as FAX(if there any near display ) press OHD/SPK key get the dial tone, dial the fax no. get the RX. tone press START. Display will show sending.
Also it can be scanned and send from memory by loading the document and dial the fax no. press START.
Your ID and fax no. can be stored at FAX setup menu.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
How do I set up on my printer to connect fax
Dear
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Thanks,.
Feb 18, 2015 | Samsung Xpress SL-C460FW Laser...
My samsung SF 560 is recieveing faxs ok but when i send a fax it is blank at receivers end??
on samsung fax / printer the visible side of the fax should be showen up to you so you can still see the writing when the machin scans the paper.
Apr 19, 2011 | Samsung Office Equipment & Supplies
Sorry my scaner not working but printer will be working please tell me whats wrong
  1. The firewall must allow the following traffic.
    • TCP on ports 9400 and 9401
    • UDP on port 6000
  2. Make sure Scan Manager is configured for the correct IP address of the printer. If Scan Manager will not launch from SmartPanel and it does not show up in Control Panel, check <WindowsDirectory>\twain_32\Samsung. Without Scan Manager installed the printer will not be able to scan to PC.
To use Scan Manager you will need to have installed and configured the following items:
  • Installed the Print Driver, including the Smart Panel application
  • Installed the Scan Driver, including the Scan Manager application
  • Have an active connection between the Printer and PC
Important: If you don't have these items in place, stop now and perform the installation.
To scan to the PC using Scan Manager, follow these steps:
  1. Right click Smart Panel in the task bar, and then select Scan Manager. (Scan Manager Admin dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=bdbe6a5u2kt1@namo.co.kr&sep=%7c
  1. Select the Printer you want to use, and then click Quick Scan. (Quick Scan dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=pdq8czuzqk7f@namo.co.kr&sep=%7c
  1. Once the Quick Scan dialog appears set the following parameters:
    • Save Location - To change the default location click the Folder Icon to Browse for Folder.
    • File Name - The default file name is the date and time the scan is performed. To change the File Name, select the File Name field.
    • File Format - The file type selected will be the default file type for each consecutive scan. Select from the following formats. (TIFF, PDF, BMP, and JPG)
    namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=q0imt82cnhs9@namo.co.kr&sep=%7c
  1. After entering the previous information, click OK. (Scan Manager appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=1oy6sc87xa6m@namo.co.kr&sep=%7c
  1. Click Scan to scan the document to the PC.
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=45q4kejs8a31@namo.co.kr&sep=%7c
For additional information about Scan Managers' features and settings, click the question mark icon (?) at the top of the application window.
Dec 23, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Requiring scanner software for samsung SCX-4216F printer
Dear Sir,
I have Samsung SCX-4216 printer. Printing, Xerox & Fax working is OK, but scan facility is not working because i missed the original software. please give me  a solution for get the original software or scan drivers.
With Regards
Mohan
Dec 27, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung 3160fn
This is a multifunctional unit: it copies, prints, faxes and scans. There are three green buttons listed as "FAX", "COPY" and "SCAN". You need to press COPY if you want to make copies, since the default setting is FAX. The user's manual contained in the CD will show you how to change the default setting to COPY.
Sep 06, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung "scx-4623f multifunction laser printer" Logo
44 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
