Question about OEM 2000 Toyota 4runner Radio / CD Player 3t135423g receiver, 1 DIN mounting, Without cassette; w/CD, 6 spkrs Bakersfield, California
How to fix a 2000 4runner cassette player
I would use a cassette adaptor to play songs from my iPod and one day I put the cassette in and it wouldn't read it. The arrow on the interface would go up, then down, then up, then down then spit the tape out. whats going on?
Goldwing casette player not playing
Pretty common problem. I knew some people who had theirs fixed, others found replacements for cheaper than repair. If it is only the motors not turning, do like I did and get a cassette adaptor. Plug the iPod into it.
Apr 15, 2014 | 1990 Honda GL 1500 SE Gold Wing
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to add an iPod Input into a Stock Radio?
<p>You can add an iPod to a stock radio in your car, even if the plant does not have an auxiliary input or iPod input using a specific number of iPod car accessories. One such accessory is a cassette adapter that plugs into your iPod as a headset, but ends on a cassette tape to your stock cassette radio. However, not all cars have cassette players, thus more accessible to the FM transmitter. <br /> <p><br /> <p>1. Connect your iPod to an FM transmitter, if you connect headphones to the iPod. <br /> <p><br /> <p>2. Connect the FM transmitter to your cigarette lighter to power and then to the transmitter. <br /> <p><br /> <p>3. Press up and down on the transmitter to the FM transmitter to change, you will pass the signal to your radio. Choose a station that is not a radio station on it so you do not interrupt the signal. <br /> <p><br /> <p>4. Set your stock radio to the channel you selected on your transmitter and then play the songs on your iPod. You will see the songs on your iPod through the radio station you selected. <br />
It will not play a song it doesnt play instead just keeps changing songs. How do i fix this
If the file is corrupt, then it will skip until it finds one that it can play. I had this on some songs I ripped from a scratched up CD. At a certain point, the files are not clear enough for the iPod/iTunes, and will be skipped. This can also happen if you've unplugged without ejecting the iPod first while you were transferring music. I would recommend either playing a different song, or if it is doing it to all of them, put the iPod into DFU mode. You should be able to google that and have no problem with it. It will wipe your iPod, however.
Nov 17, 2012 | Apple iPod 4th Generation MP3 Player
How do i replace radio cassette player with a cd player mazda 6 2002
Don't replace it. Go to Walmart and buy an adapter. It is usally at the check out somewhere and It cost about $5.00. It has a cassette that goes into the cassette player. Then you plug your ipod or whatever into the attached wire. Doesn't look cool but it works and it is inexpensive. The adapters with the cd player attached skip (we had one 20 years ago) so just buy the new kind of adapter for less and play all your up to date gadgets. Put your cd songs on your ipod or iphone. Our son uses one in his truck with his little ipod shuffle. No cd player needed.
Sep 12, 2012 | Mazda Cars & Trucks
Add the files in the folder music. but when want play there isn`t files
HI,
It is possible that the problem is it is either you are putting the song in an incorrect folder or your are suppose to use a program to sync music in the MP3 player for it to detect the audio or songs properly.
just like iTunes on an iPod if iTunes is not used then the audio can be put in the folder of the MP3 player/iPod but will not be detected when the MP3 player is used to play the song/music, Same goes for you Samsung MP3 Player I suggest you check for an application or program that you may need to use in order to get the Audio/Song/Music detect when putting them in the Samsung MP3 Player.
I hope this helps.
Have a nice day,
mvincentc
Jul 23, 2011 | Samsung YH-820 MP3 Player
4th generation ipod songs stop midway
1:delete song 2:then put the same song agin!
Jul 31, 2009 | Apple iPod classic 4th Generation
Can't play songs.
i don`t know if we can use cassette in nano.
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Jun 18, 2009 | Apple iPod nano
Song stops midway and moves on to next song
if there still new apple has an excelent return and repair program for factory defects.
Apr 15, 2009 | Apple iPod classic MP3 Player
Tape Deck in Car
Sounds like a poor "connection" between the cassette head and the head in the adaptor.
This could be caused by either head being dirty, or the tape head may be mis-alligned.
You can clean the heads with a proprietary head cleaning fluid.
Check with a standard tape.
Also, if your head unit supports it, switch the auto-reverse control. Some adaptors have dual heads for auto-revers decks, and some only have a single head.
May 07, 2008 | RCA RS2640 CD Shelf System
OEM 2000 Toyota 4runner Radio / CD Player 3t135423g receiver, 1 DIN mounting, Without cassette; w/CD, 6 spkrs Bakersfield, California Logo
Top OEM Car Audio & Video Experts
D. E. Hev
wadingriver
wadingriver
Are you an OEM Car Audio and Video Expert? Answer questions, earn points and help others
