Question about Toshiba E-studio 2500c Color Copier/booklet Maker/binder/folder/printer/scanner
Toshiba 2500c says power failure - Toshiba E-studio 2500c Color Copier/booklet Maker/binder/folder/printer/scanner
4 Suggested Answers
  • 643 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 643 Answers
SOURCE: toshiba 2500c Fax board
No need, just the fax board in order to do faxing. But if u have printer kit, u can do network fax.
Posted on Aug 25, 2009
007tech
  • 95 Answers
SOURCE: Toshiba eStudio 2500c - CA00
This is a pretty complicated issue/problem. there are 5 pages devoted to this issue in the service manual. This issue would be best handled by a technician. but you could try the following....
[CA00] Color registration abnormality
<Color toner low density>
Turn on the copier holding down 0 and 8 and wait till it boots up into its service mode..then enter code 2692 “Prevention of color toner low density / change the zero to 1.
Then change code 2693 “Prevention of color toner low density / Judged number of sheets setting” value to 40 (default 20).
Make sure you have cleaned the main charge units by fully extending the rods with the green handles for each color.(open the front door) and use the plastic wand attached to the front door to clean the laser glass for each color..there is a small **** under each color unit to slid the wand into..felt side down on the wand.
Like I said there are several other complicated ways of fixing this.
Posted on Jan 16, 2010
I have toshiba e-studio 2500c error code E030. No paper jam.
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Nov 27, 2016 | Toshiba E-studio 2500c Color...
Jan 15, 2010 | Toshiba Office Equipment & Supplies
Toshiba 2500c Fax board
Aug 25, 2009 | Toshiba E-Studio 3511 Color Copier
Check following:
May 27, 2009 | Toshiba Office Equipment & Supplies
HP 2500C Pro Series Color Ink Jet with Error Code 432
The problem is with the service station. This is the unit that the carrier "Parks itself" over when it is not printing. It cleans the print heads and collects excess ink. It also fills up with ink. and the ink dries in a big blob.
If the motor is good, if it was working it likely is, The SS probrably got jammed in the move.
Try this:
If you can move the carrier to the left with power off do so.
If not turn machine on and while carrier is to the left unplug the machine.
You need the carrier to the left to expose the SS.
Open the cover as if you were changing printheads.
Look straight down. your looking at the service station.
A shaft with wipers and a gear at one end should turn. A little resistance but jam if alot of ink is caked in the bottom of the unit.
You can clean some of this in from the top and see if the SS frees up as a test at least.
The service station can be removed if required. You need to remove the right cover from the machine.
There are three screws that you should see looking down at the SS from the top They have numbers next to them I beleive, holding the SS in. Everything that moves should move freely.
Hope this Helps Good Luck
Feb 27, 2009 | HP DeskJet 2500C Pro InkJet Printer
C448 on Toshiba e-studio 2500c
C448 indicates Heater lamp lights continuously for a certain period of time when the pressure roller temperature during ready status is higher than the specified.
1. Clear status counter
Enter 08--> 400 --> change the value from "32" to "0", press Enter and restart MFP.
If occur again, u need to check followings:
1. Check the power supply and fuser unit
2. Check the LGC board
Feb 04, 2009 | Toshiba E-Studio 161 Copier
E-studio 2500c "network host is busy"
you can try to print directly to the machine (not going through the novel system) using either apple talk or ip printing
Mar 27, 2008 | Toshiba e-Studio 205 Copier
Toshiba E-studio 2500c Color Copier/booklet Maker/binder/folder/printer/scanner Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
