Question about Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive
Wd1600aajs slave settings - Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive
  • Western Digital Master
  • 27,725 Answers
Hard Drive a Slave Drive Setting a hard drive to function as the secondary ("slave") drive allows you to use the drive solely as a storage unit. You can use the drive to back up valuable data on the primary drive without having to install or use an operating system on it. And all you need to get going is a screwdriver to pop the case open.
Power down your computer. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect all of the cables and then put the computer on a stable work surface such as a desk or a chair. Use a screwdriver to remove the screws securing the side paneling of the case. The screws are located at the back of the computer and along the edges--only remove the screws securing the case. Unhinge any case latches on the computer. Slide the side paneling of the case off the computer. Some case designs require you to remove the whole case, and some are broken down into removable panels. Remove enough of the case to have both sides of the computer exposed. Discharge any static that may have accumulated on your clothing before handling any internal components. Rub your hands against a solid metal portion of the case to discharge the static. Locate the hard drive. It should be secured in a station of bays adjacent to the motherboard--it'll also be near your DVD/CD-ROM and floppy disk drives. Remove the screws that secure the hard drive to the bay. Slowly slide the drive out of the bay. The drive will be connected to a data and power cable. You can temporarily disconnect them to take the drive out completely and give yourself more room to work with--but remember to reconnect them. Locate the jumper pins on the hard drive. There will be a diagram displaying the proper jumper settings for a given hard drive mode. Follow the diagram and set the pin cap in its slave position on the hard drive--for example, some drives may require the cap to be placed on the last two pins to set the drive as a slave.
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart you will have to have master with slave set up you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave single or master ::::: master with slave ::':: slave :::': black line between dots is plastic jumper note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s wd1600aajs slave settings - clip_image001.jpg Set Up a Slave Drive b> In a computer system, a master/slave relationship establishes the primary and secondary hard disk or optical drive status. Many computer owners install operating systems on the primary or master hard disk and use the secondary or slave disk as a storage drive for games or multimedia. Master/slave or primary/secondary relationships exist only with IDE or ATA drives. SATA, a newer drive technology, is a jumperless system and does not allow for master/slave settings, which makes SATA drives easier to install.
Shut down your computer. Unplug all cables and peripheral devices. Remove the left side panel while facing the front of the case. Remove screws, manipulate latches or perform other necessary steps to remove the panel. (Please see your computer or case manufacturer's documentation if you are unsure of how to remove the side panel, as this process varies.) Turn the case so that you are facing the open, previously left side of the case. Locate your drive bays. The 5.25-inch optical bays are at the top right and the 3.5-inch hard disk bays are towards the bottom right. You should be able to locate the necessary bay easily by matching your slave drive with the master drive. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the drive from its anti-static packaging. Locate the pins on the back of the hard disk or optical drive. Jumper configurations vary according to model and manufacturer, and most manufacturers show the configurations on the drive itself. Configure the jumper according to the hard disk manufacturer's instructions. Insert the hard disk or optical drive into the appropriate bay. Secure it by screwing in at least two mounting screws. Attach an available controller cable to your drive. Most controller cables feature a Y-split cable, which makes it easy to find and attach the secondary cable that links to your primary drive. Insert the power supply cable into the port on the drive. Again, you may be able to plug in a secondary cable split from the power supply's cable to the master drive. Double-check all connections. Remove the anti-static wrist bracelet, then reattach all cables and peripheral devices. b> Configure the BIOS b> Start the computer. Enter your BIOS by immediately pressing the BIOS setup key, as shown onscreen. (Most computers feature a "Press X to enter BIOS setup" message after you hear the computer beep. Press this key. If you do not see this message, please consult your computer's documentation, as the BIOS key varies according to your motherboard.) Navigate to system setup and allow the BIOS to auto-detect the new drive. Save and exit the BIOS. Reattach the side panel if the drive is working correctly. Hope this helps.
Posted on Jan 03, 2013
WDC WD1600AAJS-00YZCAO
this may be hardware problem.
Try by changing the new hard disk and re-window again.
Nov 05, 2013 | Dell OptiPlex 760 PC Desktop
I have a Western Digital WD1600AAJS drive. It was on a PC, got hit hard by malware. Need to copy off some critical directories from it. Plugged into another machine. Other machine will not fully boot with...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Jumpers for a PC hard drive are next to the power connector. Mostly in between the power connector and the data cable connector. These are used for setting up Master/Slave settings and also to limit capacity of the HDD seen by PC BIOS on some older hard disks. Usually settings which are selected by jumper setting to various locations are printed on the hard disk information sticker.
hope this helps
Apr 19, 2011 | Western Digital Caviar SE WD1600AAJS 160...
I need driver for my WD1600AAJB
Hard disks don't require drivers.
Please explain the problem you are having and someone here may be able to help you.
Include what OS you are running, type of motherboard you are connecting it to , etc.
Feb 24, 2011 | Western Digital Caviar SE WD1600AAJS 160...
I want to make my WD1600AAJS hard drive a master hard drive, but the port is diffrent than my other hard drives. what do i do?
A SATA drive cannot be set to master or slave like a PATA drive can. SATA only allows one device per port. If the problem is that you don't have any SATA ports in your computer, you can get a SATA host adapter card for your system, update your motherboard to a motherboard with SATA ports, or get a PATA hard drive.
Feb 23, 2011 | Western Digital WD Caviar Blue WD1600AAJS...
Just bought a new cpu, put it together and purchased the western digital 160 gb sata II model number WD1600AAJS. i am installing windows 7 on it, or attempting and it won't recognize the drive. it says it...
The drivers are not needed, West. Digital is right. Your problem is that the hard disk is not recognized by the motherboard (not the cpu). Since you didn't mentioned anything about motherboard's brand / model, I have to tell you that you have to get into the bios settings and get yout hard disk recognized by the bios. I assume that the connections are right.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 19, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Was wondering if my wd1600aajs was still under warranty
There is usually 12 months warranty with hardware, you need proof of purchase and date of purchase.
Oct 18, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Just buyed Western Digital Caviar SE WD1600AAJS 160 GB SATA
you have to enable the raid controller in the bios to see sata hdd nad have you pluged the power connector to hdd which is by the sata cable port then to your sata port in the motherboard, then install sata card drivers for your motherboard then reboot and after you have rebooted goto devise manager and see if it is reconised the driver if you have a yellow question mark then select it then right click then uninstall then click yes when removed driver goto the icon with spyglass and computer on and doubleclick on to search for new hardware once done reboot then your new hdd will be in the my computer icon.
hope this will help
Jul 08, 2008 | Western Digital Caviar SE WD1600AAJS 160...
RAID 1 not installing with WinXP32
Did you run the RAID configuration utility?
Jan 20, 2008 | Intel D875PBZ Motherboard
Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive Logo
786 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
