Blue pixel ring around outermost bottom of tv screen, got tv from neighbor , neighbor says bulb blew once and was replaced in back right hand side of tv, took tv apart to clean and projector is one ro
    Genius:
  • 1,669 Answers
Check the lens that the image is projected through!
Posted on Jan 04, 2013
SOURCE: Sony KDL-V40A12 Smashed Screen HELP!!!
??????? ? ?????? ???????????,?????????? ???????,LCD,DVD,??,??????????.
(0512) 63-33-40 ?.???????? ??.?????? 1
???????? ??: http://www.tele-servis.ru
Posted on May 25, 2008
SOURCE: Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
Posted on Jun 24, 2008
  • 668 Answers
SOURCE: blue shadow
No. I would suspect it being a Optical Block issue. I is not a pretty repair not to mention the cost factor. If you could get in touch with Hitachi Customer Service they could lead you to s service facility that could comfirm what I think.
Posted on Jun 22, 2009
Raditronic
  • 196 Answers
SOURCE: My 4 1/2 year old Sony KDF-42WE655 TV is on its
NEED A NEW OPTICAL BLOCK UNIT AND CLEAN THE DUST IN FANS
Posted on Apr 22, 2010
maatmartin7
  • 1210 Answers
SOURCE: I TURN THE TV ON
You have a defective shunt regulator. This will cause your TV to come on for 1 or 2 seconds as you describe. The IC650 is bad. The B + supplies fail to switch to full power.In layman garb, you will need a new or refurbished power supply board. There is nothing wrong with a refurbished board.A refurbished board has been tweaked (reworked to optimum performance)and many times will out live a new board. Find an authorized Philips TV shop, show them this note. Good information may result in a reasonable repair. Thanks for asking and show all hands of support!
Posted on Jun 24, 2011
How do I replace the headlights in my 1985 Lincoln town car.
To replace the headlights, you must first remove the trim ring around the headlight. There should be three or four screws holding it in place. Once the trim ring is removed, there will be four screws, two at the top and two on the bottom. Carefully remove screws and remove the retaining ring. Gently pull bulb out, unplug the wire connector. With new bulb in hand, carefully connect the wiring to back of bulb and carefully set in place. While holding the bulb in place, set retaining ring back in place over bulb and insert screws. Then replace the trim ring, tighten the screws and you are done.
Jun 12, 2010 | 1985 Lincoln Town Car
There is a thin blue vertical line, top to bottom that appears on the right hand side of the monitor,
it is a dead line much like a dead pixel the screen will need to be replaced
May 08, 2010 | Computers & Internet
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
My picture has been getting a blue area in the lower right hand corner of the screen and it is getting bigger farther along the bottom and the right side, also noticed a ring or outline of a circle when...
It is light engine that is going bad and causing blue haze/ clouds etc.
It is an expensive part, and I would recommend a new TV instead of its repair.
Thanks.
Sep 08, 2009 | Hitachi 50VF820 Projection TV
Replacing lamp for a sony lcd Kdf50WE655
it is located in the front of the set behind either a long metal strip cover or a plastic cover. some sets have wing nuts hoding the cover in place. they would be located on the left and right hand side of the set near the bottom edges.
Jan 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue Noise, left side of TV
I have the same problem -- had a Best Buy technician out 4 times so far, replaced 2 parts, adjusted the voltage, etc., but still have the same problem -- looks like there may be no solution other than replacing the TV, which is an expensive proposition considering that mine is about 18 months old.
Jun 12, 2008 | Samsung HP-S4253 Television
Jun 10, 2008 | Samsung HP-S4253 Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
